SD Card error / Unknown error
2020 9 2017-3-6
Bpup
Flight distance : 192343 ft
Norway
So i bought a SanDisk Extreme PLUS (brand new) to replace the 16gb Lexxar in my Mavic pro.
I got this error in the start, but i formated it in the Mavic and it worked just fine.
Now it gives me this error every single time i turn the Mavic pro on, both in RC mode and in WIFI.
At first, i would think i got a faulty SD card, but if i take out the sd card and put it in again (while the Mavic is on) it works very well!
Also, footage is great! so i don't know what the problem really is.
The Lexxar works just fine though... and i have tried formating the 64gb SanDisk from ExFat to Fat32 with no go.
Anyone else having simmilar problems?
[FIXED] The SD Card was faulty returned it for a new one.
2017-3-6
travelrikk
Flight distance : 4721175 ft
Malta
Have you tried formatting using a pc then re-formatting with the DJI GO4 ?
2017-3-6
Bpup
Norway
travelrikk Posted at 2017-3-6 04:10
Yes i have.
It formats fine when i reinsert the sd card while the Mavic is on, but i still get the error later on.
It says format failed when i try to do this while having the "Unknown Error"
This is also why it might be plausible that this is a software issue since it works just fine after the re-insert.
But it seems to be only me having this problem.
2017-3-6
travelrikk
Malta
Bpup Posted at 2017-3-6 04:24
Yes i have.
Your other sd card, the lexxar works fine? Might be a hardware issue with the sd card, I would contact SanDisk directly.
2017-3-6
thehippoz
Flight distance : 23 ft
I would format it fat32 64k alloc units. Then copy 64 gigs of files onto the card, check speed during copy and verify all the files are good. There's a lot of knock offs made. The color doesn't look right to me.
2017-3-6
travelrikk
Malta
https://www.raymond.cc/blog/test ... -ebay-with-h2testw/
2017-3-6
Bpup
Norway
Warning: Only 60873 of 60874 MByte tested.
The media is likely to be defective.
59.4 GByte OK (124667901 sectors)
1.5 KByte DATA LOST (3 sectors)
Details:0 KByte overwritten (0 sectors)
0 KByte slightly changed (< 8 bit/sector, 0 sectors)
1.5 KByte corrupted (3 sectors)
0 KByte aliased memory (0 sectors)
First error at offset: 0x0000000430100000
Expected: 0x0000000430100000
Found: 0x0002140200021401
H2testw version 1.3
Writing speed: 18.4 MByte/s
Reading speed: 18.7 MByte/s
H2testw v1.4
I will return this SD card to my local dealer. Thank you all very much for the help
2017-3-9
travelrikk
Malta
Bpup Posted at 2017-3-9 23:19
No worries, learnt the hard wary but sometimes it's better to pay extra and buy electronics from a trustworthy source as there a lot of counterfeits of everything out there.
2017-3-10
Bpup
Norway
I returned the Sandisk Extreme pluss and got a new. All good so far!
As i have never ever had problems with Sandisk in the past, i thougth this might be a Mavic Pro fault, but i was wrong
Thanks again!
2017-3-15
DJI-Ken
Flight distance : 1515312 ft
Bpup Posted at 2017-3-15 06:54
Once in a while I'll get a bad SD card too. Glad you've returned it and got it sorted out.
2017-3-15
