hallmark007
Flight distance : 9530285 ft
MikeQView Posted at 2017-3-9 02:40
Ok i follow your thought process on when to calibrate, (though i do have my own preference on this). But i dont get the warranty bit, when i fly, i try to ensure BEFORE flight that everything works correctly and reliably, i hate aircraft crashes, and would not want to endanger anyone i fly with or near, so to that effect i do not include warranty as a safety measure, warranty is about as much use as a chocolate teapot, if you were to crash into someone and then end up in court. Also redundancy systems do not tell you when to calibrate, that is controlled by a different system.
Ok so I said redundancy, warnings so, your right about that, as you will see in post #6, this is how I prepare for flying, and to check everything is working as good as it should be,
Your point about warranty, there is a certain amount of safety in preparing your AC under manufacturer recommended practices, if you choose to ignore these, and get your set up wrong, you also fly with the same risks you pointed out. |
