Obstacle avoidance mid air warning
12Next >
6804 40 2017-3-12
FlyingHighNL
Flight distance : 116355 ft
Today I've done 3 flights and every flight gave me an obstacle avoidance warning mid air. one time when I was about 60 meters High I received a warning that an obstacle was avoided and that I should review my flight course. But there wasn't anything in front of the drone, no bird nothing. Even when flying away from direct sunlight I received this warning. What shoult I check?
2017-3-12
rreindl
Flight distance : 6491926 ft
I received the same warming but only when I was facing the Sun. Was the Sun reflecting off the clouds extra brightly?
2017-3-12
FlyingHighNL
rreindl Posted at 2017-3-12 07:32
Today is a really bright day
2017-3-12
FlyingHighNL
2017-3-12
Gusmtb
Flight distance : 35249 ft
Had it the other day while trying to get sunrise, ended up turning off the vision sensors, turned them back once finished filming.
2017-3-12
BigKitty
Flight distance : 148907 ft
Mexico
had it myself...did not see anything on my screen at the time. However checked the video on my mac after and it was a bird! Be careful!
2017-3-12
Please try not to shoot into the sun, or tilt the camera down more.
Test more and keep us posted.
2017-3-13
R&L Aerial
Flight distance : 298100 ft
DJI Mindy Posted at 2017-3-13 01:30
I've never had this problem till the .500 update, something changed and it would be nice if DJI changed it back.
2017-3-13
Gmman
Flight distance : 1003150 ft
R&L Aerial  Posted at 2017-3-13 01:52
I agree. No matter what I did other than point the camera almost straight down.
2017-3-13
Having this issue when shoot into the sun or not?
Did you capture some screenshots of the warning?
2017-3-13
Gmman Posted at 2017-3-13 01:59
2017-3-13
GroveTuckey
Flight distance : 264134 ft
I get it on cloudy days also.
2017-3-13
R&L Aerial
DJI Mindy Posted at 2017-3-13 03:37
The mavic beeps and stops regardless if it's facing the sun or facing the opposite direction.
2017-3-13
harfordhawk
Flight distance : 18668 ft
tilt the camera down more? I fail to understand how that would affect OA sensors..
2017-3-13
Fractures
Flight distance : 635531 ft
I get these warnings at dusk, when the sun is almost set and when it is very bright outside. If I'm flying in either of these conditions I usually just turn the sensors off. Hardfordhawk I think you are correct and Mindy was just mistaken. the OA sensors are giving the warning not the camera.
2017-3-13
DJI-Ken
Flight distance : 1515312 ft
You can also try calibrating the sensors, mine too gave me a few warnings but it was also sunny out.
2017-3-13
mewchi
Flight distance : 614931 ft
I had this happen during an RTH.. The drone just sat out over some trees about 35 feet away and refused to move forward even though there was nothing in the way except the sun.   This is a serious bug if you ask me.  Maybe they should have put some sonar facing forward as well.   Belt and suspenders ya know.
2017-3-13
ExiledBlue
Flight distance : 5928881 ft
Thailand
I have never had a single problem with my Mavic, UNTIL the last few days, every single flight, I am having obstacle avoidance warnings.
Flying in bright sunny conditions, but not into the sun.
2017-3-13
FlyingHighNL
ExiledBlue Posted at 2017-3-13 20:04
That is my experience as well. Could it be the latest firmware update causes this? Hope DJI is watching this thread  with us.
2017-3-15
DroneFlying
Flight distance : 10774613 ft
By any chance did you recently upgrade the firmware? The reason I ask is that it seemed that OA warnings became much more frequent after I upgraded to v01.03.0500.
2017-3-15
ExiledBlue
Thailand
DroneFlying Posted at 2017-3-15 12:06
Yes, I upgraded on the day the update was released.
2017-3-15
fans06e428ab
ExiledBlue Posted at 2017-3-15 22:52
Just had this happen the other day, and almost resulted in a lost mavic. The obstacle avoidance kicked on when it 300+ ft high over open farm fields. On screen, everything on the ground was highlighted in red and we were unable to do anything to get the Mavic to fly back. Battery was getting low, so a RTH was inititiated several times, but would cancel due to the obstacle warnings. During RTH, the Mavic was moving away from the home point. Battery finally got so low, that it went into landing mode. Luckily we were able to locate the Mavic by it map location and recover it. It was sunny, and the home position was due west, so it does appear that the sunlight may have caused this.
2017-6-2
MTUFLYER28
Flight distance : 8477969 ft
I have this occur usually when flying around sunset anytime I'm repositioning where the forward sensors yaw through the direction the sun is in.  I assume it's just due to the rapid change in lighting across the forward vision sensor.
2017-6-2
fansde5f456a
I have the same issue.  Flying 150 feet over farmers fields.  I usually fly late in the day around sunset so I am guessing that is it.  First flight was good changed battery second flight was non stop warnings closer to sunset. Previously sunsets over the river was the same thing. Mavic should fix it!!
2017-7-12
CharlieFliesDro
Flight distance : 36148 ft
if your flying above obstacles Like tall Trees,Building,Towers,and such just turn off your forward sensor
just make sure your RTH alt is set higher Then surrounding trees and other obstacles near your Home Port
2017-7-12
STRIDE8
Flight distance : 1382431 ft
That happened to me as well. I was flying towards the sun but I think a dragonfly buzzed me
2017-7-12
UCBarkeeper
Flight distance : 616982 ft
Switzerland
fans06e428ab Posted at 2017-6-2 19:50
just flick it to sports mode next time and bring it in manually.
2017-7-13
iDsigns
Flight distance : 93750 ft
Last sunday i had this problem as well it then came down, the Mavic stopped and dropped down to the floor... the Mavic is now at DJI for analyzing.. Hope they come with something because i really like to know if this is an firmware error or an pilot error. what ever the case may be. I personally think this is something DJI can fix because i dont even know how to directly stop the motors of the Mavic.. ill keep you up to date ones i know more!
2017-10-12
AsturLoko
Flight distance : 327234 ft
Another one here with the same problem.
In my case I can confirm that the error has nothing to do with the sun, reflections or the things that have been said here, always happens.
I "solve" it by eliminating the sensors in the RTH, but it is something that should not be so.
When I bought the Mavic this did not happen, so it is clear to me that this is a problem of the latest firmwares
2018-2-8
Mcbrich
Flight distance : 1412395 ft
It happened to me today. I was flying away from the sun at an altitude of about 120 feet and I got the same warning. I have all the latest updates installed. Strange since nothing was in front of the Mavic.
2018-2-8
fans4ebd7c9f
Flight distance : 111247 ft
Purchased a new Platinum Pro and in 4 flights have had 8 or 9 of these warning. If it doesn’t stop I will be returning it to the store as I haven’t got £1500 to spend on something that doesn’t work as it should.
2018-7-7
Picanoc Jack
Flight distance : 10326581 ft
happens a lot,  sun is the culprit, nothing to worry about.
2018-7-7
S.J
Flight distance : 322454 ft
Kuwait
Picanoc Jack Posted at 2018-7-7 23:48
Were you all able to solve this problem. Did DJI came up with a firmware upgrade . I 'm planning to buy a DJI Mavic Pro.
2018-7-8
Picanoc Jack
S.J Posted at 2018-7-8 10:15
my height was very high so I figured that it couldn't be a tree nor a bird,  I fooled around with the gimbal and it went away,  so I wanted to experiment and started going around in a circle,  it happened every time that I circled that point.  the warning  goes away when the AC is pointed at another direction, now I don't know if that helped you out,  but maybe someone else with more experience can help you with that issue S.J
2018-7-8
S.J
Picanoc Jack Posted at 2018-7-8 13:26
Dont worry i ll use mod DJI GO4 app.
2018-7-10
A CW
Flight distance : 13877205 ft
Cal the sensors in assistant 2
2018-7-10
40buickcoupe
DJI please look into this had a buddy in town last week and both of ours did the same thing at different times of day. Never had that before software update. No issues to get it down but don't want to run into one
2018-7-10
Guido-Italy
Flight distance : 477008 ft
same problem to me last flights with .300 firmware version. During obstacle warning MP were with sun 90 degrees on the right I think that should be wind to create this issue
2018-7-12
Exib
Flight distance : 153760 ft
Yes I have had the same thing its the sun glare, first time it happened I thought it was a bird strike as I was flying towards the sun
2018-7-12
mrrz500n
Flight distance : 9551 ft
It has happened to me a couple times. Flying away from the sun both times. It would not let me go forward until I disabled it . Flew 100 yards or so . Then enabled it.
2020-6-22
12Next >
