Dangair
The levelling does not need to be surgical. There are other factors that will have greater effect than being off by a degree or two, such as wind or illusion... What say you? Yes clouds slowly moving behind your aircraft can trick you into believing your aircraft is drifting. The aircraft, when in GPS lock should compensate for small indescrepancies. If you are flying in free willy mode you are the level so for beginners... BEWARE. |
