iKjell
![](https://forum44.djicdn.com/data/attachment/common/c2/common_12_usergroup_icon.png) lvl.3
Flight distance : 583094 ft
Norway
These forums might not give the Mavic a fair chance, since it tends to be the tiny fraction of people having issues, that speak out the most here, so here is my issue-free view of it.
After giving up on both at P3 4K and a P3 Advanced, both which had continously compass errors (got a lot of ATTI-training though ), I closed my eyes, and ordered the Mavic.
With two compasses, instead of only one, I was hoping (and praying) the probability of issues, should at least reduce.
The Mavic finally arrived last week, and can easily say that this was an upgrade I do not regret one second.
Really surprised of how small it is, compared to the Phantoms. It will definately get more hours in the air, just because of this, since it is so easy bring along.
I like the smaller controller as well, although it can be a little fiddly to get hooked up with the phone. Also have not got used to the second screen yet, but I am sure it will come with more practice, as it is probably better at showing critial information.
So, after some charging and updating of aircraft, controller and batteries, I finally took it out for some first system checks. With my previous experience of the Phantoms in mind, it was all about taking it easy. This little thing, though, was just rock solid. If it wasn't for the sound, it would be possible to mistake it for being fixed on a pole or something. This definately helped on a slightly damaged confidence from the compass broken Phantoms.
Headed for some large open fields for the first real flight, and it just kept on impressing. Ran through a lot of systems and options, and I cannot think of any occations where it did not behave as expected, and I have not seen it go into ATTI once (which is a relief, because that was really causing a pain with the Phantoms). Not even in Sport mode with maximum throttle. Had it out at +1500 meters (in line of sight, although you cannot really see it at that distance, but from camera and map I could navigate in the scenery and "see" where it was), and still all connection bars at 100%
Once, I have had an intereference warning, but that was after it had landed, and probably due to the controller coming too close to some sensors, when I was picking it up.
Talking about picking it up - my landing pad blew away during one of my landings due to the downwash, so I dared to go for a hand catch, since it is so stable. And that was really no problem at all. It is so small and light, so it is quite easy to grip it without getting even close to the propellers. I did not turn of the VPS first, so it fought back a short moment before the motors stopped, but really noe issues at all.
Before this, I also tried RTH with the Precision landing. Just awesome - came back from anywhere, to land within 10cm from take-off.
One thing I could not figure out, was if it is possible to initiate Precision landing without the RTH? Could be occasions when I have brought it back home myself, and I would just have it to land itself, without bothering to line up against the landing pad manually.
So, as an aircraft, this little machine has so far surpassed my expectations by far. As a camera though, I would probably be a bit more modest.
As I have read about, the 1080 HD option, is really useless. In 60 or 96fps, it gets so pixelated (moire?), that if I had guessed the resolution of the video, it would probably be more in the 480*640 area...
2.7K though, looks very good, but sometimes when there is a lot of movement, I would really like to have the 60fps. It might be that 1280*720 is better at high fps, but have not yet tried this.
All in all, I am absolutely delighted with the Mavic. Can't really wait to get it back in the air, and learn more about it's features.
Will keep on reading and learning, but any tips on settings, especially the camera, would be appreciated for a relatively fresh pilot/cameraman ![](//forum44.djicdn.com/static/image/smiley/default/smile.gif) |
