DJI GO 4 For Android Has Been Released (V4.0.5)
12
9857 61 2017-3-14
BengalBoy
Flight distance : 11134446 ft
Constant crashes on HTC One M8 using Android 6.0.  Switched to older HTC One M7 running Android 5.0 and had three flights with no crashes.  DJI Go 4 was slow to synch flight data such as altitude after take off, otherwise, great performance.  Android 5.0 seems to work better for me.
2017-4-1
MikeQView
Go 4.0.5  leaving video lag smears all over the screen,  this is terrible and makes the app virtually useless,  i am running a motorola play x,  which has worked superbly until i  upgraded to FW .400   from .200 and what ever the Go app was at up till February ,   since then i have had nothing but trouble,  with firmware and Go app,  i  dont even think the apple stuff gets away without issues either, as its reported that some of their features dont work any more.    PLEASE DJI , FIX THE APP AND FIRMWARE !   its really important !
2017-4-2
fans8fbb746d
Flight distance : 10075 ft
MavicUAV Posted at 2017-3-31 11:21
Is there a trick to get the offline maps? When I start the Go 4 App there is a offline maps section in the main menu (on the startpage). But the only maps I can see in the list are in China. Offline map capability is a really important feature imho, ideally we should at least be able to use OpenStreetMap maps (like all offline capable navigation systems do these days). Or have an input field where we can provide our own map server via wifi or locally on the android device.
A cool feature would also be another intelligent flight mode: "Map Area -> Ascent to max allowed alt, tilt gimbal down and follow a snake pattern while taking pictures of the area below that will be used as offline pseudo satellite view in the Go App.
Are you running a custom ROM without Google Play Services installed by any chance? It seems those services are used to check the location and provide region-specific maps for download (I had the same issue running LineageOS w/o those services installed).
2017-4-2
Jet0308
So far so good here.
2017-4-2
Faso
Flight distance : 206831 ft
Fatboysdotco Posted at 2017-3-15 07:04
it would be really nice to be able to use my pixel and save video without adding music
agreed! I would love to use my pixel xl but it crashes and then the flight record is all messed up. A device is a device, I don't know why they can't make it work with everything. There's plenty of apps(Or should I say EVERY app) that work with EVERY device. Why is DJI different?
2017-4-3
Orion 303
Flight distance : 22907 ft
Poland
Why does it require access to phone permissions -- making calls and rerouting calls?
2017-4-3
Bill in Ohio
Eric13 Posted at 2017-3-19 10:54
I did the downgrade as well and NOTHING has improved.
Cleared the cache yesterday which some people recommend: No changes.
Did you completely remove all dji go and dji go4  folders in the phones internal memory before installing.  I have Samsung S7 and the app crashes at some point on each flight. I have been just flying it around the neighbor hood close to home just to be safe.  Prior to this all has been good, except one unexplained problem and 2 where I was to close to transformers and a power line.
2017-4-3
Bill in Ohio
Matt W Ruff Posted at 2017-3-28 14:12
Yup that worked use the QR code above and it works.....Google play no!
OK - I am confused, the link you are referring to is for the iphone or the android?  I also have a Galaxy S7 and until I upgraded to 7.X I and the new DJI GO4 app I was doing fine with my Mavic.  Yesterday weather was decent, but windy, so I flew 4 times  near my house and each one resulted in a DJI App crash.
So which phone are you using the link for?
2017-4-3
Eric13
Flight distance : 13982031 ft
Bill in Ohio Posted at 2017-4-3 07:17
The downgrade removes everything from the device. It's like factory reset to a previous system.
No need to delete ceratin folders prior to downgrade.
2017-4-3
Ostrov.ee
Estonia
Hello. Can you do the "Panorama" and "Draw" modes for DJI Go 4 (Mavic Pro)?
2017-4-3
lo-tek
Flight distance : 86952 ft
I had several app crashes on my Galaxy S7e yesterday.  It's a bit spooky.  Can we please get this fixed?  thanks!
2017-4-3
fansb73c528e
Flight distance : 163474 ft
New Zealand
Malsua Posted at 2017-3-18 04:50
I have a K1 Shield that I use.  I had the same issue.   I downgraded it to 6.0.1 Marshmellow from Nougat and all the problems stopped.
I only use this K1 for the Mavic and had disabled everything but maps and DJI Go 4.
I use a new phone not even on the list OPPO is the company, runs even better than my last phone the Samsung Galaxy S5
2017-4-3
Bill in Ohio
Post - which GO4 version, which device (phone, tablet) and model name, which operating system version (5.x, 6.x, 7.x, ).  Orherwise your post doesn't tell us much.
2017-4-4
Bill in Ohio
Are you referring to:  Going to DJI.com > Mavic > Support and downloading the Android app by using the QR Code there and you phones's reader to download the .apk file for the dji Go 4 app?
Also did you use dji assistant 2 to refresh or download the firmware?
2017-4-4
Bill in Ohio
Bill in Ohio Posted at 2017-4-4 06:17
I guess I should have said, I have downloaded from DJI Assistant 2 the firmware and installed to both RC and drone.  Also used the QR Code located in dji.com >  mavic >  support > under either downloads or software to reinstall my dji go 4 app.  So all firmware and software updates were done through dji.  I am now waiting for good weather to find out if it made any difference.  I will update as soon as I get a chance to fly.
2017-4-4
patman89
Flight distance : 288327 ft
Is there a board to discuss feature requests for further app development? I have one thing which I would like to see in an upcoming update :-)
Everytime I change the control-mode on my Mavic (eg from Normal to Active Track) the DJI GO 4 App looses the photo-format setting I have set  (JPG+RAW) . It always resets to JPG only.
I have opened a topic for that a few days ago. Don't know if this is a firmware problem or an app problem.
2017-4-5
nitramf
iperov Posted at 2017-3-29 02:36
HELP PLEASE!
Cannot do first start!
I had the same issue, my solution was to quit the app completly and to tilt the phone back (as you hold it normally in your hands). After restarting the app it worked in the portrait mode
2017-4-7
nitramf
fLaMePr0oF Posted at 2017-3-30 07:19
P1 Interoperability defect in DJI GO 4 App Android: V4.0.5 - When used with a Huawei P9 (stock firmware) it is not possible to complete the activation process for a new mavic Pro.
When the user reaches the third screen of the activation process; "LCD Screen" which shows info on the various elements of the remore LCD screen, the controls "Next" top right and the back arrow top left are inoperable; tapping them has no response.  The info on the screen can be scrolled, so it is clear that the app has not crashed, but it is impossible for the user to progress beyond this screen and activate their drone.
Try to restart the app while holding your phone in portrait mode, that worked for me.
If it is already opened in landscape it won't switch to portrait.
2017-4-7
Xman1
App works pretty good on a Sony Xperia X for about 15 min.  Seems right at the 15 min mark or somewhere around there, it will crash on schedule.
2017-4-9
Xman1
Xman1 Posted at 2017-4-9 09:02
Going to run a test.  Just a hypothesis is that the app is going into some sort of battery standby mode, so I am going to remove battery optimization from the app to see if it still crashes after 15 min.
2017-4-9
Xman1
Xman1 Posted at 2017-4-9 09:33
Test failed.  Crashed at the 15 min mark again.
2017-4-9
Vegaslightsss
Flight distance : 47080 ft
Lenovo Quadcore with the android device 6 works really well with dgi go 3 and 4, Pilot on my p4p v 2.0 and Inspire 1. I know GO4 lists Android 5 needed. Samsung is hit and miss, Nexus seems to solid.
2019-5-28
12
