ImHereToCrash
Flight distance : 5381368 ft
to answer the original question: in the US they do not define specifically what is VLoS to begin with.. they openly state it and broadly so.. the way i interpreted it is simply the maximum potential line of sight.. there is a math formula for this as well..
Line of Sight = √ (2*height1) + √ (2*height2)
this means if you are 6 feet tall, and flying drone 400 feet AGL, VLoS is 31 miles. technically impossible.... mmmm..maybe? but it is a visual line of sight that is the formula for calculating the distance to each of the point's horizons.. the drone at 400 feet up has 28 mile horizon and you as a person have a 3 mile horizon.. the FAA intentionally does not explicitly state what VLoS is because it is naturally broad term. and as long as the POV is fairly lag free, im happy with it remaining vague.. again i like flying via POV, many people do.. if that is how most comfortable flying and you fly most safe with POV, no reason anyone should say different.. if i was forced to fly visually only offscreen then no... i would have probably killed someone already.. i mean has anyone thought about parallaxing effect? its very hard to judge distances of things that are offset of you.. using pov solves this..
as for is it illegal to fly over other people's property in the US? no absolutely not illegal. the airspace above your property doesn't belong to you as a landowner anymore in the states.. used to be a time when you owned everything below your feet and above the skies... but that is no longer possible at this point. however there is a thing called courtesy, if someone doesn't want to be disturbed or anything and they bring it up, legally you dont have to listen, but i mean,...give them a break..
is it illegal to shoot a drone down in the US? technically speaking it is illegal even if you own the drone and it is airborne, however if you own it and on your own property away from people, i doubt anyone will come after you not even the FAA will bother... however if it isn't your drone, then all i have to say is, best of luck in court.. even if a state says it's ok, federal law overrides it, and im sure the drone owner will appeal it all the way if the state lets it go. however discharging a firearm in a neighborhood at a drone is incredibly stupid and is already illegal unless protecting yourself from harm.. but shooting a drone out of the sky in a neighborhood, comeply illegal even if no federal law against it, discharging firearm within yards of other people/homes...laws against that already. not to mention if ur unfortinate enough to live in some states that hate you so much even if you had a home invasion its invalid reason to dischasrge firearm around others.. i beleive it is called "castle laws" some states do not respect them
is it disturbing the peice in the us? this is impossible to determine here... many reasons why.. first of all what determined disruption? certain local areas have different measures, some places noise is measured via a meter, some places its discretion.. other places you have to try really hard to get disturbing the peace charged against you, more likely to get disorderly conduct for not listening to the officer advising you to leave.... some places dont even have an ordinance against noise and disruptions..
