Bill in Ohio
seugnimod Posted at 2017-3-31 07:36
No problem. The other day I had to install Litchi to ignore NFZ's as I was in one, but inside a closed warehouse. If your problem is that, try it.
I just wanted the info as the only time (so far) that I was in an NFZ, prior to launch it made me click basically that 1) I know I am in an NFZ and 2) I take all responsibility for flying in an NFZ. I then could take off. It was a large suburban area, so aircraft would be operating at least 300 feet (if not higher), so I stayed low just above the houses and only once went up to 150 ft. I also knew from a lot of time there that aircraft do not fly over this town. I was also basically just showing my drone to my daughter and didn't go more than 300 feet from where I was.
I do want to know where the NFZs are, so I can use the drone to show me what is around. B4Ufly works OK, but you have to shift the point around to make all the NFZs show.
Thanks,
