Punchbuggy
Flight distance : 483166 ft
DJI-Jamie Posted at 2017-4-5 09:19
Even stainless steel can rust from the exposure of seawater for extensive amounts of time if left unchecked. It is less susceptible to rusting in general, but it's not 100% when it's not taken care of for months. If you are someone who goes to the beach once and a while, then you're probably not going to have to baby it to that extent. If you're someone who plans to fly regularly at the beach with a lot of low shots, however, then you would want to keep an eye on it.
Haven't thought much about this sort of scenario, but perhaps dabbing some Vaseline over each screw hole prior to such flights? May seem a little extreme, but if anyone is that worried that should do the trick. |
