Brian Fist
Flight distance : 19928 ft
Yeah, but a slow card will slow down the writes to the point of holding back the hardware in the P4Pro. ie, if you try to write to too slow a card in 4k/60fps it will kick out of recording altogether.
I would imagine if the card you have is slower, than it only makes sense that it would "skip" writing sets due to the same reason.
Also, no one has stated how fast the hardware in the bird actually *CAN* write to the card, just that the write spec published is 100mbps. Now that sounds exactly like a generalized specification, not a absolute maximum based upon implementation. Just like USB 2.0 is 480mbps, yet a ton of devices only get to a fraction of that based upon design, as well as USB 3.0 being 5Gbps, yet for card readers it is more like 150mbps even under USB 3.0. In that example why don't USB 2.0 card readers read at more than 8-9MBps when they should be able to handle at least 45-50MBps based upon a 480mbps max throughput (use a USB 2.0 gigabit ethernet for comparison and they get at least 400mbps throughput, so why not SD card readers?).
Again, just saying that the Micro SD card used *does* play a factor if it cannot keep up with the max write speeds of the AC. |
