djordan2
Flight distance : 79291 ft
zeekman Posted at 2017-4-8 19:05
Yes there was a warning pop up saying that video downlink has been lost and do I want to RTH. I said yes and the rest is a gone drone. I had no control of the AC after that.
It appears that the wind had control of your aircraft. Wind forecasts in general are for surface winds. But to a pilot, the winds aloft are what is important. And the winds aloft speed and direction vary from altitude to altitude. A general aviation pilot will check the winds aloft during his weather briefing to see what altitude, among other things, would be best for him to fly to achieve the best performance of his aircraft. We drone pilots can do the same thing. If you want to know the winds aloft speed and direction at what ever altitude you want to fly, try this method. Launch the drone and go up to the maximum altitude you expect to reach. Then turn off the GPS feature. If there is any wind at all, the drone will instantly start to fly away. Watch the readout on your display. Particularly the Horizontal speed. The drone will think it is hovering in still air, which it is in regards to the air directly around it. But the whole volume of air is moving downwind and taking the drone with it. The readout on your display is ground speed, not airspeed. See which way the drone is moving, and take note of the direction it is moving in. That will tell you what the winds are like up there where the drone is, but not down below where you are. And remember, weather forecasts to the general public are for surface winds, not winds aloft.
One other thing. The RTH feature does not take into consideration wind speeds. Never fly to your maximum published range downwind. |
