pan_de_ron
Flight distance : 36017 ft
DJI Mindy Posted at 2017-4-5 23:19
For taking off the first time, the Home point will be refreshed automatically with good GPS quality, or it will refresh until the signal quality becomes good after taking off.
If the aircraft is not powered off but being moved to another location with shutting down the motors, then it takes off again, the Home point will not refresh with poor GPS quality and the previous Home point will be used.
Even if the GPS quality is enhanced afterwards, the Home point will not be refreshed due to it is not the first-time taking off after the aircraft is powered on.
Hi Mindy,
Thanks for the info. Could someone at DJI test this:
From Launch Pad:
1. GPS signal is good. 1st: Take off. You should hear/see: "Home Point is set".
2. Land on the same exact spot from the 1st take off.
3. GPS signal is good. 2nd take off. Should I hear/see: "Home point is set"?
The Green H Bubble is set at the same location on the map on the 1st and 2nd take off.
I appreciate all the help your team does.
