Nigel_
Flight distance : 388642 ft
"I like to inquire info on the use of the P4P at open sea."
Note that the warrantee does not include water damage, and salt spray does not go well with electronics over time, also it does not float which means that you can't return it for warrantee issues to be fixed. You should consider it a disposable item when used at sea!
"We intend to use a drone at sea, launching and retrieving from a small inflatable boat (6.5m)."
This is a bit dangerous without plenty of practice, you need to launch it from your hands, held above head height and catch it on return. Do not try it unless there is good lighting conditions for the Vision Positioning System to be able to hold it steady above you, and only do it in calm conditions, do not take off from the boat itself as it is likely to either hit you or hit the water.
" What are, if any, the limitations for launching at sea?
Is this necessary to do a full calibration each time you start-up (fly) the drone? or can this be by-passed (e.g. done on land)?"
Never do a calibration on a boat, you should only be doing a calibration once or twice a year anyway and 100m away from any metal for the compass calibration.
"For our (research) purposes, the exact flying height is required. Reading from many other posts, this is unlikely to be achievable using dji installed GPS/barometric values.
Does anybody have experience installing/using extra devices to measure more exact height?"
The ultrasonic sensors will give an accurate height up to 15m, they don't work beyond that. The barometer is fairly accurate, and at sea where there will not be big temperature variations I would expect it to be plenty accurate enough. Of course I don't know what accuracy you need, but if you check the take off height (which will be 0) and the landing height (which may be a few meters out) then you pretty much know the accuracy of the rest of the readings on a short flight. I think on most flights over sea you will find take off and landing well within 10m and probably within 5m.
If you are adding extra equipment such as data loggers then beware of blocking the ultrasonic and vision sensors, there is not much room where it is safe to put stuff. If you block the ultrasonics then it can fall out of the sky unexpectedly and if you block the vision sensors then it will become very hard to hand catch at sea in even a light breeze.
" Thanks for your input"
Please post your results and experiences in return... |
