Phantomski
Flight distance : 14869882 ft
HWCM Posted at 2017-4-11 22:24
Word of advise, loose the carbon props and the lights. The props have a history of flying of or breaking mid flight. Those LED strips have a habit of getting caught up in the props.
Also, why the leg extenders? They are unnecessary and just add weight.
Are you a model airplane flyer? Why the red on green to the sides instead of front to back?
Agreed on the CF, but these have plastic hubs, so I should be ok, but yes, I usually fly standard props - but since I got these I figured I'd play with them.. but yes, I gave same advice as you did, to many ;)
BTW, these CF are supposedly DJI, so.. I assume that is why plastic hubs, and hope they will work well, but.. I may chose to dump them.. I have heard a lot of what u said here....
As for the lights, I got them glued well, as well as zipties to prevent the issue if I miss something during preflight checks. I do like the colors for night flying - and red/green, as it is standard coloring for aircraft, including rotorcraft. This is an RGB strip, so it can do all sorts of fun stuff....
The leg extenders, because when i take off or land in the mountains, it comes in handy. Yes, I can hand launch and hand catch, but I can also take off and land from uneven or rocky terrain.
I realize none of it is neccessary... but I ma vain, so vain....!
