userfa702488ce
Hello
My problem is that they did two warranty repairs and the aircraft still has serious problems. I received the aircraft on April 5, 2017, the first thing I did was remove it from its package and make a test flight to check the state of the aircraft after the repair covered by the warranty of technical support dji Holland, The repair had failed the same mistakes as when a month before I sent it to technical support dji Holland. Now what is the problem that is causing me dji technical support Netherlands, I've been writing emails for 6 days until I get tired of writing yes I get no results from dji technical support The Netherlands seems to not pay me much attention and it's like wanting to give up
Here I leave the reference of the repairs in case you leave and you want to check them
Regarding the case: CAS-487479-K4Q9K5
Referring to case CAS-443203-B0G2L2
This can be checked in progress for repairs in the Netherlands technical support page
Greetings and thank you |
