rfrye
Flight distance : 309606 ft
Last Friday I saw the firmware upgrade notice come in.
I downloaded the firmware updated zip file, immediately.
Saturday I tried numerous times to install the upgrade as instructed even though my app said I was on the latest firmware (of which I wasn't)
I called DJI Help Line and the guy said I was "good-to-go" since my app said I was on the latest firmware. I did not believe this advice.
Sunday, still persistent to try to install the new firmware, I concentrated on what Dundee and arunmetha prescribed for their update procedures.
No luck with either procedure.
THEN - I deleted the new firmware zip file I had downloaded on Friday and started all over.
I reformatted my SD card to clear the card of the Friday download.
I re-download the zip file from DJI and moved it to the root directory of my reformatted and clean SD card.
I then deleted all files on this SD card except the WM610_FW_V01.02.0017 (bin)
I reviewed both Dundee's and arunmetha's methods and proceeded to install.
It "took" on both the craft and the remote. It gave me all the updated versions I was missing.
I checked the critical settings and they all stayed as previously set.
I checked the IMU and it needs recalibrated before I fly tomorrow.
(prior to new firmware install IMU had shown within tolerances - SO, be sure to check your IMU after updating.
What are the chances DJI changed this new firmware build after releasing it Friday morning?
(since my second download worked)
Tell me what you think.
