DAFlys
Flight distance : 312090263 ft
leeblynch@gmail Posted at 2015-9-19 19:31
Gentlemen. I have figured it out. You have to use an arbor press and press the shaft out of the motor. After removing the clip and the bushing, press out the shaft from the bottom towards the top. Look at the motor, see the screw threads, look below them and you will see a separation line between the top of the bell housing and the threads. That is where the shaft will separate from. I will shoot a video and post it on youtube soon. You will be able to replace and or clean bearings in doing this. The motor is a little difficult to come apart but it will. You do not have to remove the shaft all the way, just until you are able to pull the two pieces apart.
I think I would just replace the motor than do this, I think it will be more reliable in the long term as the tolerances to reassemble this correctly must be very tight. |
