hallmark007
Flight distance : 9827923 ft
You would be better having a read of the manual.
Your not supposed to calibrate your compass or IMU before every flight, in fact if you read the manual it will tell you NOT to calibrate unless prompted, if you continue to do this you will almost certainly end up with bad calibrations and this will cause you real problems... |
