Ayumikosan
here a list what i have allready tried. I dont know how often i have now proceed the upgrades but it was offten 20~40times?!
Preperation:
- Format SD-Card with Windows and with DJI GO 4 App (with Fat32 on Windows)
- Reinstall Assistant 2 with allow install unsigned drivers in Windows 10
- Start Video-Record before upgrade to 800 or 900 (with and without)
- Tried 3 different PC's (unfortunately all with Windows 10 newest Version)
- Tried 2 different mobile devices (Samsung Galxy S7, Samsung XCover 3)
- Reset to factory defaults with Assistant 2.
Upgrades:
* Upgrade von 350 to 800, 350 to 900, 811 to 800, 811 to 900 (Only 350 and 811 itself update with success)
- Use DJI GO 4 automatical update on startscreen to 900.
- Use DJI GO 4 hidden upgrade/downgrade menu (See *)
- Use Assistant 2 with Firmware-Update menu (See *)
- Testet on Assistant 2 with and without connect phone to the RC
- Testet on Assistant 2 with and without RC
- Tried 2 different SD-Cards. The one that was shipped with the Mavic and a 32GB transcend Class 10
In the logs it always look the same as here (The AC reboots at 57% the first time... then few minutes later a second time and then it says failed)
[07:12:56][upgrade1860Ex ] receive upgrade push status from 0x0801 to 0x0a01, UST_Upgrading, progress: 58
[07:12:58][upgrade1860Ex ] receive upgrade push status from 0x0801 to 0x0a01, UST_Upgrading, progress: 58
[07:13:00][upgrade1860Ex ] receive upgrade push status from 0x0801 to 0x0a01, UST_Upgrading, progress: 58
[07:13:00][upgrade1860Ex ] receive upgrade push status from 0x0801 to 0x0a01, UST_Upgrading, progress: 57
[07:13:02][upgrade1860Ex ] receive upgrade push status from 0x0801 to 0x0a01, UST_Upgrading, progress: 57
[07:13:03][upgrade1860Ex ] receive upgrade push status from 0x0801 to 0x0a01, UST_Finish, type: 2
[07:13:03][upgrade1860Ex ] ======================= UPGRADE FAILURE: push upgrade failed status, error code: 0x020102
[07:13:03][upgrade1860Ex ] ======================= Time : 645.18 second
[07:13:03][DiagMsg ] push upgrade failed status, error code: 0x020102
[07:13:03][UpgradeMgr ] Lb_dm3xx_sky(1) result false
[07:13:03][UpgradeManager ] WebActionResult:
[07:13:03][UpgradeMgr ] upgrade_pack_file_data time used: 85.647 Second
[07:13:03][UpgradeMgr ] enable_upgrading_flag: false
[07:13:08][SerialIo ] Free COM8 success!
[07:13:08][CommandIo ] DJIDeviceCommandIo closed.
[07:13:08][DevMgr ] DevRemoved, LittlePilot, wm220, 1.3.3.132, f1703f45f71f14fa07f5090eecee9c90e5b658d7
Interessting. In the Logs there is a line... Its a Mavic not a phantom4 did that mean something?
[18:43:48][P4Device2 ] Open comm port : RNDIS_DJI_PHANTOM4_RNDIS&COM8 true |
