Mavic Pro firmware upgrade failed again and again..
107450 1101 2017-5-3
DJI Susan
Wanbli Posted at 6-1 08:35
I have a Mavic Pro with Version 01.03.0550 that will NOT update to any version. I don't see this Version 01.03.0350 mentioned in Post 40 in my Assistant 2 Firmware list, so I can't try to update to it. I have Uploaded Many Logs after Update Failed. Can you please make this Beta Version 01.03.0350 available in my Assistant 2 so I can fix this issue, PLEASE?!! My email is wanb1i@live.com.
Received the 01.03.0350 firmware, thanks, but it fails everytime at 15% (see Pic)
Hi there, with the error code 0x032800, you may try to restart the drone and DJI Assistant 2 and update the firmware again. If the issue persists, you may need to send the drone back for further diagnosis.
2021-6-1
Wanbli
Flight distance : 3848497 ft
DJI Susan Posted at 6-1 22:29
Thanks for the reply. I spent the entire day yesterday trying to get this drone to update. I'm over it!
It is now in auction on eBay!
2021-6-2
DJI Susan
Wanbli Posted at 6-2 07:14
Sorry to read about this. If there is anything else I can assist you with, please feel free to let me know.
2021-6-2
fadi1984
Flight distance : 748 ft
New Zealand
hi there i have same problem stuck at 56% plz help
2021-10-7
DJI Wanda
fadi1984 Posted at 10-7 14:11
Hello, there. Sorry for any inconvenience. Could you please tell us your firmware version and whether there were error messages prompted during the update?
2021-10-7
fadi1984
New Zealand
DJI Wanda Posted at 10-7 19:39
hi wanda v01.04.0500 and now i cannot connect to pc stuck at loop connect and disconnectthe message was failure to update then i try to update from the app but there was no video feed and same thing failuer to update
2021-10-8
fadi1984
New Zealand
hi wanda here the update as soon as i turn it off,now i cannot connect to the RC any more just 2red light at front and flashing yellow at the back the RC show connecting but never really connect
2021-10-8
fadi1984
New Zealand
any one can help plz i cannot use the drone any more it stuck at 56% when update
2021-10-10
fadi1984
New Zealand
anybody can help
2021-10-11
fadi1984
New Zealand
i have been trying over and over but all end at the same 56% then it stop
2021-10-11
fadi1984
New Zealand
any one here can help plz
2021-10-11
DJI Wanda
fadi1984 Posted at 10-11 23:59
Hello, fadi. Sorry for the late response. Please check my PM
2021-10-13
KillSwitch8
DJI Mindy Posted at 2018-5-31 02:37
We have added again, could you please have a try?
Hi DJI, I am on firmware version 01.04:0500 and cannot downgrade or refresh. My gimbal has also stopped working and i get error 0x020404. Please send me beta to fix this on ulhaqzubair@yahoo.co.uk.Thank you.
2021-11-1
KillSwitch8
Hi DJI, I am on firmware version 01.04:0500 and cannot downgrade or refresh. My gimbal has also stopped working and i get error 0x020404. Please send me beta to fix this on ulhaqzubair@yahoo.co.uk. Thank you.
2021-11-1
KillSwitch8 Posted at 11-1 14:05
Hi there, may I confirm that do you mean you cannot control the gimbal via the remote controller? If so, you may need to send it back for diagnosis and repair. https://repair.dji.com/repair/index?site=brandsite&from=nav
2021-11-3
djiuser_g80d34MVv3YO
Flight distance : 54137 ft
South Africa
DJI Diana Posted at 2017-7-24 20:01
Copy that, Please refer to  the steps below to upgrade it via the DJI Assistant 2 again.
1. Log into your DJI account.
2.Upgrade the firmware V1.3.8.10 or V1.3.8.11.
Hi i realise this is a very old post but im fighting a uphill battle trying to updat my mavic pro ive tried everything it just keep failing
2021-12-7
ayasso
Brazil
Não consigo fazer a atualização trava em 24%, preciso tentar também V01.03.0350 beta, por favor conta DJI   airyasso@gmail.com
2022-8-1
Hubertus
Im also having trouble with the update. It always fails hit 44% can you please send me the Beta firmware?
Leonard.FIebig@googlemail.com
2023-8-2
DJI Tony
Hubertus Posted at 8-2 15:13
Hi there, Hubertus. Sorry for the inconvenience. Have you already tried these notes:
• Before updating, ensure that the battery level of the device (remote controller or aircraft) is above 50%.
• While updating, do not power off the aircraft or disconnect the USB cable. Otherwise, the update may fail.
• While updating, the device may automatically reboot several times. When rebooting, it is normal for the remote controller to disconnect from the aircraft automatically. Do nothing before the update is completed to avoid affecting the normal updating process.
We recommend using the app for updating. If the update fails, please refer to the method below and try again:
1. Power off and reboot the remote controller and aircraft. Try updating again.
2. If possible, use another mobile device and try again. For example, switch an iOS device to an Android device.
3. If the update using the app still fails, we recommend using DJI Assistant 2 for updating if you have a computer on hand.
I hope it helps. If these have already been tried, don't hesitate to reach back so we can assist you further. Have a great day ahead.
2023-8-2
djiuser_XgJ9J8nMP2yN
fans7cb13127 Posted at 2017-5-3 07:13
here you go
the last two tries. we sent the mavic back to the seller for changing the drone.
i could also send you more logs from assistant 2 on macos, but i have to know where the files are saved?
Hey just wondering if this drone belongs to you
2023-11-17
Mohammed Al-Faraj
Saudi Arabia
I have same problem, black screen in my mobile  when i connected to teh RC and DJI mavic pro, and i tried several times to downgrade or refresh the curent version but won't completed, i contacted local technician he told me the camera signal cable most probably damaged, my dron tumbled from 120m hight after battery suden dead.
1-31 12:38
Carlosdron 2
Flight distance : 14754 ft
Hi DJI, I also ave the same problem , I am on firmware version 01.03:0200 and cannot upgrade firmware, with full batteries, and with DJI asssitant 2 at  windows PC with usb cable  and DJI Go4 at ipad mini . My gimbal has also stopped working and i get error reading sd card. No crashes. While trying to upgrade firmware  the process stops at 56 % and I got error 0x02803 . Please send me beta to fix this on carlosrubiolainez@gmail.com . Thank you very much in advance.
2-17 00:14
