SkunkWerxs
Flight distance : 231217 ft
Danny-B- Posted at 2017-5-5 15:56
The mavic using Occusync which as i'm led to believe is on the 2.4ghz band but the P4's TX and RX is 2.4 and 5.8ghz so that would explain why its more reliable in high noise enviroments, the likelyhood is that the P4 can adjust to compensate, while the mavic is stuck on 2.4ghz band.
Personally i think other than a better camera, more sensors and a better DJI go app, the mavic is awsome. The TX using hall sensors isnt a bad idea ... some of the latest TX's such as the taranis have got upgraded gimbals that use hall sensors too, it's only going to be a bad thing if your too close to magnetic interference, which i tend not to when i fly.
Hi Danny, The Mavic consists of 3 different signal modes:-
1) 20 MHz mode - having 63 channels, from Channel 1 @ 2,410.5MHz to Channel
63 @ 2,472.5MHz, i.e. with 1MHz channel separation
2) 10MHz mode - having 73 channels, from Channel 1 @ 2,405.5MHz to Channel
73 @ 2,477.5MHz, i.e. with 1MHz channel separation
3) 1.4MHz mode - having 38 channels, from Channel 1 @ 2,403.5MHz to Chanel
38 @ 2,477.5MHz, i.e. with 2MHz channel separation
Duty cycles for the 3 different transmission modes are 85.15%, 84.16% & 10.4% for the
20MHz mode, the 10MHz mode, and the 1.4MHz mode
anybody please correct me if I'm wrong
FlySafe-FlyFree |
