fanse2d09664
Flight distance : 379344 ft
Hey Rich or Donnie
I purchased a used X3 from ebay and it was listed for parts it has the same issue, will record video and pictures to SD card but no image transmission. I also have the Osmo Handle and it transmits and image to the go app while using it on the osmo handle but not on my Inspire 1. I have 2 other x3 cameras that have broken gimbals so I thought maybe I could swap out the boards inside the camera and so I tried it and I then get an image in the go app with both the Inspire 1 and the osmo handle but the gimbal doesn't work so I put the original boards back onto it and the gimbal works fine and back to the same thing no image in the go app on the inspire 1 but will record to the SD card and it works on the Osmo handle. Do you think this also has the same issue with a corrupted module? all FW is current according to the app. Also is there a way I could use the boards from the other x3 cameras I have and get the gimbal to function correctly cause that would defiantly be cheaper than sending it to DJI and probably faster. Thanks |
