Mark The Droner
Flight distance : 2917 ft
The video you provided tells the story. Great video btw.
I'm sorry, I didn't state what I meant correctly. YOu're right, FPV signal has nothing to do with RTH. So doing nothing at the first sign of FPV problems would not be best. What I meant to say was when you lose FPV, unless you have a live 3G tracker or you can see it with your own eyes, it is probably best to RTH the AC one way or another. The foolproof way is to turn off your controller. You can also press the RTH button, of course, but it's not foolproof.
When I'm flying and lose FPV, I'm in the habit of just continuting to blast ahead at full speed - but I have a live tracker so I am watching it on my second tablet. I know where it's going, how fast, how high, battery voltage, etc. I know my AC will lose the control signal eventually due to distance and turn around on its own - but I'll be watching it when it does. Without a live tracker though, that would be kind of crazy.
As far as what actually happened with your flight, forget about the FPV connection and the log for a moment. Let's just examine the control signal via the video.
It started to coast to a stop at about 1:35 or so. This is when the control signal became intermittent apparently. We can presume the signal was intermittent because otherwise it would have RTH'd at around 1:38. Or maybe you just let up on the forward throttle leaving the sticks centered. Whichever. So it hovered. It began to rise at 1:42. We know it was you elevating it via your left controller stick because it didn't turn towards home yet. At 1:43 it stopped elevating because it lost the control signal again - because it's intermittent. So it hovered for three seconds. At 1:46 it turned towards home clearly indicating RTH. Then it began to rise towards the RTH height. It rose a bit more until it received the intermittent control signal once again. This is at about 1:53. This is where the rise to RTH height was interrupted. So now it won't rise to RTH height because it is programmed to come directly home at the given height after it received any stick command. So it went straight towards home and into the tree at 2:16. But just before it hit the tree, you regained your telemetry signal which informed you that the AC was in RTH. But it was actually in RTH mode for about 30 secs.
