RedChops
Flight distance : 215213 ft
hallmark007 Posted at 2017-5-24 06:07
There are all sorts of warning beeping and alarms on jet airliner, there is also constant beeping on lorries when they are reversing just like your Mavic when it stops reversing or when your Mavic has RTH or you have taken back control then beeping stops.
When you are doing your commercial exam for instance , you would not be aloud turn of this failsafe beeping because it's a safety measure.
There are warnings, yes, but not a constant screeching beep. I know, I've heard it. The lorry example is possibly the worst case anybody can make with this argument though. Think about it. You're driving the lorry the entire time. This is the same as if you're just flying the drone in reverse. There's no beep for that, is there? Plus this horn is actually attached to the rear of the lorry, letting people you cant see know that there is a large vehicle in reverse and the driver may not be able to see you. If you want to think down this line, then the beep should be on the drone, not the controller. The bystanders should be watching for the drone, not calling the police on me because they think I have a bomb in my hands or something.
If I've made a series of errors and somehow I fall ill while flying my drone, well, first of all I don't see how the controller beeping helps anything. If I'm unconscious and cannot warn people of an incoming drone flying automatically, the beep is actually FAR less safe. People are now watching me and the loud controller and not watching for the drone that is likely flying silently right at their heads from an area they're not looking. |
