Ex Machina
Flight distance : 1806362 ft
PanaceaBeachBum Posted at 2017-5-24 15:43
As far as I know, how do I tell from the software on tablet? I can swipe the left panel and one way it says my username here which is the screen I was on when I hit sync, the other way has a pic of the drone and my Initials at the top of the screen. Both show the same stats
Ok, try this: go into the DJI Go 4 app's Forums section and see if you can post to this thread -- if you can, then the app is using the same account and should work. If you can't, or the post shows up under a different username, then that could explain the problem.
My Go 4 app has my actual first name on both the sync screen and the Me screen, but when I post to the forum it still comes across as Ex Machina.
