RichJ53
Flight distance : 1837356 ft
davidmartingraf Posted at 2018-3-28 22:22
I just unboxed my Tello and had my maiden flight and it performed as I expected. I had a few error messages pop up saying to land the craft immediately, stating the vision positioning system was disabled because of low ambient light?
There also was no way on the settings menu to calibrate the second setting under the compass for gravity? I didn't know if this was something not yet enabled that will be incorporated in a later firmware update? Anyway, pretty straightforward as I expected, minus the errors.
Hi again
So glad you put your Tello into the air. Please check that your IR downward sensors are clean (blow some air into these. Look at my screenshot while in low light, it only says to fly with caution.
1) The IMU can be calibrated with the App while the drone is setting on a flat surface while following the instructions. See screenshot showing this active when the Tello is connected.
2) The center of Gravity Calibration can only be done while the Tello is hovering in place. Do not do this in the wind. See screenshot showing this active while in the hover.
Not much to adjust on the Tello, it is designed to be easy for the beginners
Rich
This post contains more resources
You need to Login Before they can download or view these resources, Don’t have an account?Register now
x
