Jenee 2
Flight distance : 7852129 ft
You need to connect your phone to the RC either by the side port or the usb port on the bottom of the RC. If you are using the bottom usb port then make sure there is no cable connected to the side port.
To see the camera and other settings, you need to have the RC, Mavic and your phone all turned on and the DJI GO 4 app running.
You need to have enabled Multiple Flight Modes in the settings at some point, even if you later turn it off. This will give you the ability to see the advanced flight modes which you can access from the screen of your phone in the DJI GO 4 app. There are 3 icons on the left hand side and the bottom one is for the advanced flight modes. In there you will find Cinematic mode. |
