How-to reset goggles?
12Next >
23520 41 2017-5-29
DRONE-flies-YOU
Flight distance : 1638323 ft
How do I REALLY reset the DJI Goggles to like when I (very first time) first took them out of the box?
1.  Resetting using "Reset All" within the Goggles menu doesn't really reset them.  They remain linked to my Mavic & all my settings remain.
2.  Resetting using Assistant 1.1.1 FAILS everytime I try.
2017-5-29
DJI Natalia
Flight distance : 318 ft
I've reported your feedback to the engineers, will come back to you once I hear from them, thanks for your support!
2017-5-30
neonadler
Currently, it's not supported to reset Goggles to very first time status, "Reset All" is just to reset the settings like brightness, volume, language to default value, but not include the linking status with drone and camera settings.
2017-6-4
DRONE-flies-YOU
DJI Natalia Posted at 2017-5-30 02:35
Anything on this?  No hurry as now my Mavic is a brick from firmware .800.  It won't update & batteries won't turn off.
2017-6-8
DJI Natalia
DRONE-flies-YOU Posted at 2017-6-8 16:34
Our R&D engineers replied you at 3#, sorry I should have informed you about that.
May I know how did you upgrade Mavic?
Please restart it then connect it to a PC with Assistant 2 installed, reset it firstly then upgrade it again.
2017-6-8
DRONE-flies-YOU
DJI Natalia Posted at 2017-6-8 19:37
Not being able to RESET these is NOT an answer. That's bogus.
Also, only 1 of my batteries bricked, not the Mavic.  Just glad I have an extra battery (even then the update only went to 99% & didn't pickup on the reboot to make it 100%).  I only updated using Assistant. 1 battery remains on or something. The middle 2 lights stay on & slow blink LIKE OTHER PEOPLE have experienced.
2017-6-9
DJI Natalia
DRONE-flies-YOU Posted at 2017-6-9 06:15
Have you tried to insert that "bricked" battery to aircraft and try to upgrade it through DJI GO 4 again?
2017-6-9
DRONE-flies-YOU
DJI Natalia Posted at 2017-6-9 22:05
Yes, but I always update via DJI Assistant.  So after it froze @ 44% 2 times with an error, I tried DJI GO 4.
I solved the battery issue ANOTHER WAY, however!
2017-6-11
DJI Natalia
DRONE-flies-YOU Posted at 2017-6-11 08:39
Glad to hear you resolved the issue.
2017-6-12
fansfe804677
Flight distance : 148914 ft
Finland
Hi Natalia,
Really you should implement the Factory reset soon. I have a pair of goggles that are on a loan for review purposes. Now because of this issue I cannot return them since the initial activation process cannot be started again for the next user.
And since these are a review unit I kind of dont want them to contain any data from me when I return them.
So do you or rest of DJI have any timeline when this will be fixed?
2017-6-26
fanseabb8ad0
Flight distance : 102657 ft
Hello, I have the same problem.
I've bought the DJI Goggles someone who has activated this with his Mavic Pro.
I have a Phantom 4, with which the DJI Goggles also works together.
I get however neither a firmware update nor a reset with the DJI Goggles started. DJI Assistent 2 remains after the download and does not begin with the firmware update.
2017-6-27
fanseabb8ad0
fanseabb8ad0 Posted at 2017-6-27 22:07
I Found this error, The Error is part of the windows PC.
A other PC help to solve this problem.
2017-6-28
Damjo
Flight distance : 324826 ft
My goggles are stuck in Chinese and I cant get them back to English. Factory reset fails in assistant.
2017-7-7
Xerxes1359
This is crazy. So let me make sure I have this straight: The Goggles are permanently tied to the original account. That means you can’t sell or buy them used!? What complete idiot thought this was acceptable? I guess DJI is going to have many returned to vendor units from store returns. Insane.
2017-8-10
fans2f5b91cc
Flight distance : 210912 ft
Brazil
I just had a problem, head tracking gimbal stopped working on Mavic and I wanted to rollback firmware. Theres no way to do that. I was told to return the device back to DJI... have a case number created for that.
2017-8-27
DJI Diana
Flight distance : 2408 ft
fans2f5b91cc Posted at 2017-8-27 21:01
Could you please provide more details for about the head tracking issue for better assistance? Besides, what is your case number?
2017-8-28
Biggles
Flight distance : 1717867 ft
Portugal
Damjo Posted at 2017-7-7 22:05
Same here. Unpacked the goggles, charged the battery, while chosing the languagge unfortunately hit the wrong language. Now it is stuck in Chinese or Japanese and I can´t get it back to English
2017-8-28
Biggles Posted at 2017-8-28 11:39
The language cannot be selected in Settings? There is an option called ''Reset All'' in Settings.
Please keep us updated if it works. Thanks.
2017-8-28
masterx
Flight distance : 14639 ft
Norway
masterx Posted at 2017-9-10 07:01
Hi..
My Goggles Take forever to boot up. UP to a 1 min.. And sometimes they even freeze up the menu on the Phantom. Watching a demovideo on the goggles is pointless. Tried to downgrade/roll back the Firmware but fals with Djigo and assistent.
Hi..
My Goggles Take forever to boot up. UP to a 1 min.. And sometimes they even freeze up the menu on the Phantom. Watching a demovideo on the goggles is pointless. Tried to downgrade/rollback the Firmware but fails with Djigo and assistent.
2017-9-10
masterx
Norway
Hi..
2017-9-10
Hi..
How and when did this issue happen? Can you show us the picture of freezing up please?
2017-9-10
iloco34
Flight distance : 463 ft
Hello
I made a mistake when I initialized my goggles. I have validated a bad language. I tried to reset the factory settings with dji assistant but the program does not work. The "reset all" menu in the settings does nothing. How can I make my goggles in English?
thank you
2017-9-12
iloco34 Posted at 2017-9-12 08:28
Hello
thank you
Please connect Goggles to DJI Assistant 2 and restore to factory default. RESTORE FACTORY DEFAULT.png
2017-9-13
Jontidy
Flight distance : 299616 ft
Thailand
DJI Mindy Posted at 2017-9-13 03:25
Please connect Goggles to DJI Assistant 2 and restore to factory default.[view_image]
This doesn't work! fails every time. This is the same for everybody. I don't know 1 person that this procedure has worked for.
So basically DJI has not only made a terrible product that is as immersive as holding your phone up to your face with a sun hood on (I've tried it, it's exactly the same) but I also cannot sell them because they are locked to my account and drone. This is insane!
2017-9-13
DRONE-flies-YOU
Yes what the heck is wrong with you? We need help & this canned-text suggestion has already BEEN EXHAUSTED. Months of this garbage is ABSURD!
2017-9-13
Jontidy Posted at 2017-9-13 07:05
Jontidy, sorry for the unpleasant experience with our product, we will feedback this issue to our engineers for analysis. Please post the firmware version here firstly, thank you.
2017-9-14
Kurt
Did this ever get resolved? I Have the exact same problem whereby the goggles are stuck in Chinese.
2018-7-10
Kurt@vectorform.com Posted at 2018-7-10 19:09
Sorry to hear that, please try my post in 18# to see if it helps.
2018-7-10
djiuser_ioRX55vxltKs
DJI Mindy - or any DJI people...
Please see my attached picture "DJI_Goggles_NO_FACT_RESET_2018-09-15_0753.png" (it is also posted to the cloud and linked above)
In the image, it looks just like Mindy's POST #23 above - EXCEPT I do NOT have a "Restore Factory Defaults" -
In my REFURB Goggles, recently purchased direct from DJI, everything works AOK, but it is STUCK in JAPANESE/CHINESE and does not have any settings to reset to ENGLISH.
I will repeat.. I have REFRESHED to the LATEST Firmware in the REFURB goggles with ASSIST 2, there is NO 'Restore Factory Defaults" as in Post #23 above from DJI Mindy. See linked pic to verify this.
Please advise and thanks!
2018-9-15
DRONE-flies-YOU!
djiuser_ioRX55vxltKs Posted at 2018-9-15 06:15
Hi, sorry for your frustration. Have you tried learning Chinese?
2018-9-15
Hi there, sorry for the troubles on switching the language, did you try ''Reset All'' in Settings? It will reset the settings like brightness, volume, language to the default value, thank you.
2018-9-17
DRONE-flies-YOU! Posted at 2018-9-15 15:47
Ah So! Sage advice.
Confucius say, "The will to win, the desire to succeed, the urge to reach your full potential... these are the keys that will unlock the door to personal excellence."
My desire right now is to unlock the Chines and open the door to the English version!
Will post below if RESET (see #18) works.
Thanks!
2018-9-19
DJI Mindy Posted at 2018-9-17 00:32
Hi Mindy - Got it fixed!
It was part my fault (no surprise there) and partly DJI's fault (shocker!).
I was scrolling up and down thru the Goggles Settings (as you suggested) but there was no language select settings (only Volume, Brightness, IMU, etc.).
So I got on the phone to Tech Support today... within a few minutes I was on the phone with somebody and I had the Chinese Goggles up and running... they prompted me "Keep scrolling down."
Sure enuf, there was an Icon with a Letter A and a Globe (icon for 'language' I guess). And off that sub-menu was English and bingo (English for 'score!') it popped right into English.
The DJI part was that there is no traditional 'More' or 'Down Arrow' or 'Something' that told me there was 'more icons below.' I had no idea from the interface that there was more stuff below.
At any rate, setting back to English is a piece of cake - if you know to 'keep scrolling'!
So, "Keep scrolling folks and happy flying!"
2018-9-19
djiuser_ioRX55vxltKs Posted at 2018-9-19 17:25
Glad to know the issue has been figured out, we will forward your concern to our engineers to keep optimizing our device, please let us know if you have any further issue.
2018-9-19
LetThereBeLight
Flight distance : 15889 ft
Hungary
Hi, I bought a Dji Goggles, is the reset is fixed already or can I use it at all? Or will be my flight goes to the original owners account?
2019-1-13
djiuser_VddIhTMNIr5o
Flight distance : 1374990 ft
It's funny how many people (like me) choose the wrong language out of the box and had to spend time searching for an the answer instead of watching how-to setup DJI FPV videos on YouTube.   I do wonder if DJI made this pitfall as a joke or just dummy proofed their gear.
Update:  Wow, still can't figure this out.  I went through all the options and there is no logo with an A on it.  What are you talking about?  What menu is that in?  Count from the bottom, 1, 2, 3.   I can't be the only one trying to learn Chinese!
Update:  Ok, I was able to find the menu to change the languages.  On the menu on the left side, choose the bottom option (press right on the joystick on Settings).  Then choose the bottom option that is displayed on the right side (About).  A new screen replaces the right side with new options.  Choose the second from the bottom, but make sure you scroll down as there are more options below the first page.  The second from the bottom is languages.  Hopefully I articulated what is needed for others to follow.
Update:  I hit reset all button instead of the lanuages and it brought up the first screen where you choose languages.  The reset all button is like the languages button, but the first one from the bottom.
2021-3-21
fans5a1b28a6
Flight distance : 15180 ft
Hi! my V2 Goggles are stuck on FPV mode and I the option to toggle back disappeared.... I'm trying to find a way to reset the Goggles but it seems like it is impossible. Any advice? I'm starting to loose faith on DJI customer support.
2021-3-27
Ginmax
Flight distance : 2363091 ft
Russia
fans5a1b28a6 Posted at 3-27 12:30
2021-4-17
djiuser_AJyziQSaedHT
djiuser_VddIhTMNIr5o Posted at 3-21 22:43
This was the post that helped me the most getting mine back to the "select language" page. Bear in mind, these are not EXACT instructions! Looking through the goggles, use the D5 button and toggle to the bottom selection "settings".. Select "settings". Now.. Using the same button (D5), toggle your way to the bottom of the list. (There is at least 2 pages..) Now, you're almost there.. Somewhere near the bottom *second from the last?) is a numeric entry (answer/selection) that YOU CAN READ, That's NOT the one you want, select and open the one before it and the one after it. You'll know you have the right one when what pops up are 2 boxes, and the one on the right is written in RED. (Has the distinct "are you sure?" feeling to it!!! Select this and you'll find yourself back on the "select language" page.
NOW, PAY ATTENTION HERE!!!
Once I got back to the "select language" page, I caught myself MAKING THE SAME MISTAKE!!!! Go slow and BE CAREFUL! It's very easy to send yourself RIGHT BACK TO CHINA!!!.
Good Luck! I was at it for about 5 hours trying different things and reading posts like this! ;-)
Here's some thoughts after it's all been fixed..
1. Don't be afraid to CHANGE anything! Once you are back into English, you will be able to change them back of restore everything to default settings anyways!
2. Remember, there is the same # of options in Chinese as there are in English. If you can find a breakdown that explains what the individual selections/options mean, you will have located where you need to be to make the changes you want.. All you have to do is basically COUNT and not freak out over not being able to read the words!
Please Let Me Know If This Helps and PAY IT FORWARD!!!
2021-10-22
djiuser_onE0ug1Io9yU
Flight distance : 322388 ft
hello I bought the DJI v2 goggles quite recently in March and I have a problem after connecting to a computer to update or refresh, I cannot solve this problem
2022-6-5
12Next >
