Are filters required?
12Next >
6225 50 2017-5-30
Xman1
I seem to be able to capture decent shots without any filters, so just wondering if they are mandatory?  I am not the professional photographer here.  I watch a few vids online and the filters seems to take the details out of water to me among other things.  Each one of them trying to capture the perfect 60 shutter speed with 100 ISO.  I guess the point I am trying to make is I am not convinced yet.
A couple non-filtered captures I have done (Unprocessed):
2017-5-30
Bent Kangaroo
Flight distance : 362510 ft
After viewing them i am convinced you need filters.
Buy some ND filters and start producing quality images.
Dont post any clips of your vid because the high shutter speed will be so evident that you will have to delete this post.
2017-5-30
Xman1
Bent Kangaroo Posted at 2017-5-30 17:21
What??!!!  OK, you cracked me up!
2017-5-30
PM160Mavic
Flight distance : 303219 ft
lol that was pretty funny. To be honest, the filters give you more of a cinematic feel to the video. Giving you some natural motion blur when moving which actually comes out really nice. YouTube some videos comparing shooting with and without. You'll see why people buy them.  I would grab them and enjoy.
2017-5-30
Bent Kangaroo
Glad i was able to crack you up.
Now post some video showing what happens when you allow shutter speed to dictate quality.
A still frame is no evidence of good footage my friend, especially when dealing with this underwhelming mavic camera.
2017-5-30
Heavysledz
Flight distance : 819491 ft
ND filters are not mandatory but if you want to maximize the quality of your video (and pics too), they certainly will give you much more usable spectrum when post processing....
2017-5-30
dronist
Really nice landscape Xman.
BTW, I don't use filter either and I don't do post edit.
Did you borrowed a Mercedes to go up that high.
2017-5-30
seeker_ktf_
Flight distance : 218474 ft
It's a little unfortunate but the others speak the truth.  On a clear sunny day new noon. you're going to get a lot of whacky flicker or "jello" without a filter.  It's more or less unavoidable.  I use a polarizing filter all the time now.  Even if there's no need for an ND filter, the polarization part takes a lot of the sky out as well as haze apparent in in the second photo.  In the first grab, the sky is heavily affecting the metering, so that the ground is too dark and the polarizing part will help with that.  It's good over water too.
At the same time, it really depends what you're going for.  If you're really more interested in flying and don't mind the occasional glitch, you probably don't need filters.  You'll want to get habit of setting all of the exposure parameters manually.  It doesn't take a long time to learn.
2017-5-30
Xman1
dronist Posted at 2017-5-30 18:04
I got an altitude boost when the AMG driver got beat by my sleeper Boxster and he blew his top!  So yes, it took a Merc to get that high.
2017-5-30
Xman1
seeker_ktf_ Posted at 2017-5-30 18:10
I just would think it a hassle to figure out which one to pop on there is why I ask.  I am on the fence on getting a set.  Maybe I will, but didn't want to waste the money for something I wouldn't use.
Note the first shot I didn't have enough light and I should have opened it up.  The second two I did a little better I think.
2017-5-30
Xman1
Heavysledz Posted at 2017-5-30 17:52
I guess you probably hit the head on the nail here....  How much post processing do I really want to do?
Maybe I need to experiment with it for a while to find out how much I can tolerate.
2017-5-30
dronist
Xman1 Posted at 2017-5-30 18:29
I did not have my sun glasses on but I am pretty sure I saw you getting towed up the mountain by the AMG and not the other way around. Come on, I won't judge you!
2017-5-30
Heavysledz
Xman1 Posted at 2017-5-30 18:37
to get the most out of the picture or video you will likely do some post processing regardless. The appropriate ND filter for the given light conditions will only give you more range in your adjustments when you do post process it....without a filter, you will likely not have enough adjustment in post processing and could have unusable video footage.
2017-5-30
Bent Kangaroo
Xman1 Posted at 2017-5-30 17:22
Did the others responding crack you up also?
You can buy filters one at a time if you dont wish to make full payment for the full range upfront which you might not require. This way you can see for yourself and decide if you want more.
I buy from ebay for around $10 delivered.
So far have the ND16 and 32 and will probably grab the 8 next time.
Only after you see the difference, will you see your initial response as inadequate.
2017-5-30
thehippoz
Flight distance : 23 ft
Heavysledz Posted at 2017-5-30 19:37
This is so true. I like to use a uv when possible, but it's summer now. Your looking at shutter speeds 1600+ without a nd
2017-5-30
cristianc
Flight distance : 1008143 ft
I personally don't use filters either, in saying that I wouldn't mind giving them a try.
2017-5-30
Bent Kangaroo
cristianc Posted at 2017-5-30 21:58
Here are some from BG
https://www.banggood.com/Camera- ... 1.html?rmmds=search
They look like the design to pass the gimbal thrashing at startup.
2017-5-30
Nees
Flight distance : 80991 ft
Belgium
Filters are only needed for filming. TBH, it is best to have a as high as possible shutter with the mavic, as it slightly moves, the higher the shutter, less chance the image will become blurry.
2017-5-30
b0n3
Flight distance : 21083 ft
Guys what are you talking about!???
For the still photo you don't need any filters on the Mavic, especially ND!!!
For the photo faster shutter speed is better, for the video - visa versa.
Regarding CPL filter for the Mavic - this is the most useless thing, cause you need constantly rotate it, how can you do it in the mid air? )Only Karlson can handle with it )
2017-5-31
GMG
Flight distance : 3632605 ft
I've seen at least one post of a flyer posting with/without comparisons using ND filters.  May be worth doing a google to check them out.
FWIW, I'm really happy with the Cinematic Series, which I bought directly from Polar Pro and use them all the time.  I was impressed enough by their customer service and the product quality that I posted about it yesterday.
2017-5-31
thehippoz
b0n3 Posted at 2017-5-31 00:03
Pretty sure he is talking about video. He's looking at 60 shutter and 100 iso. I shoot over 100 shutter, it seems to be the sweet spot with mavic. 60 he's right, it turns trees into potatoes.
Cpl adds a bit more saturation to your videos. But your right about the adjustment, can spin it all you want and never get it perfect like taking a still with a camera.
2017-5-31
Xman1
Polarized or not?
2017-5-31
Xman1
I think I got an answer...  Polarized for water shots, normal for land shots.  So now I have to get two sets.....
The DJI ones are flimsy it looks like, so that leaves these:
I have found the following chart on approximate times to use them from one of the threads in this forum:
I think I have a clear path now.  I just want to read up on alternatives but it is increasingly clear that these are the best.
My one gripe is that to take pictures, you don't want them, but to take video you do...  I guess you can't have your cake and eat it too in this scenario...  And I always want to eat my cake since what is the point of even having a cake if you can't eat it?
2017-5-31
Lucas775
Flight distance : 50642090 ft
What is post processing?
2017-5-31
Xman1
Lucas775 Posted at 2017-5-31 16:35
Manipulating the color / sharpness / saturation on the back end in your NLE.
2017-5-31
PM160Mavic
Watch this video
2017-5-31
PM160Mavic
That would be editing a photo or video after shooting it.
2017-5-31
Xman1
After research, I got the Polar Pro six pack.  I guess I will learn soon enough how well they work.  Not sure I want to use the PL at all times, and the six pack comes with both PL and non-PL, but a bit pricey at $150.
What direction should the filter be in for proper polarization?  Is it marked on it?
2017-6-5
thehippoz
Yeah, only have uv and cpl here and nd 4-32. Like to see how testing goes on those pl+nd xman. I've been thinking about getting the denoiser 3 from red giant. They have a half off discount for teachers and students. Emailed them about it and they'll give it to retired teachers too.
2017-6-5
Xman1
thehippoz Posted at 2017-6-5 13:12
Will do.
Note I could have used half off.  These things are bank!
2017-6-5
Xman1
Note:  I am getting sucked into going to Alaska next month, so I guess I will get to test the Polarization over water.  We shall see just how clueless I am in making them work now.
Filters are schedueled to arrive tomorrow.  I hope they fit in the fly more bag.
2017-6-6
Lucas775
Does Amazon sell good ND filters?
2017-6-6
Xman1
Lucas775 Posted at 2017-6-6 17:26
That is where I bought them - Amazon.  UPS says by 8PM tomorrow.  Might not be in time to get any footage.
This is what I got:  https://www.amazon.com/Polar-Pro-Filters-Filters-Cinema-6-Pack/dp/B01MQUMIQ4
2017-6-6
Lucas775
Xman1 Posted at 2017-6-6 17:44
Thanks for the link, I will hang on to it until you post your first video using a filter.
2017-6-6
Xman1
Lucas775 Posted at 2017-6-6 17:51
My first attempt at using the filter will take me some time to learn.  To be honest, my video's suck compared to what a lot of people do here which is why when I think, this is awesome!!....  I then look at what is being posted and it is not that awesome compared to theirs.
Full disclosure there.
I will get some Alaska video though.  I have to.  Plan to track some bears and compare the size to the bears in my area.
OK fine...  Here is one of my test timelapse videos...    You might recognize the mountains from the pics above.  And no...  I didn't plan for a rainbow to appear, I just got lucky.  Music is from a Coldplay track.
2017-6-6
Lucas775
Xman1 Posted at 2017-6-6 17:58
You're right it sucked...j/k I can already tell the difference.  Nice job, but that rainbow though...keep posting them vids.
2017-6-6
Bill Drones
Wow, that first poster is a straight up d!ck... Get over yourself man! Geez...
You don't need filters for photos because you can change the shutter speed to account for the crazy amount of light you will likely be getting when shooting in the sky, with a drone. You need the filters for when you do video, because you want to keep the shutter speed lower (1/60 - if you shoot 30fps and 1/50 - if you shoot 24fps). You want to use one of these two combinations to create a natural looking motion blur, which is what our human eyes are used to seeing. If you shoot in one of those two fps without an ND filter (sunglasses for your camera), your highlights will be crazy blown out during the day, if you try to keep the shutter in the 1/50-1/60 range. You can raise the shutter to account for the high amount of sunlight, but then your footage is going to look like a soap opera, rather than a movie. That's where the ND filters come in. It allows you to keep a nice, evenly exposed image, and keep your shutter in that Goldilocks zone.
2017-6-6
fansbab5d456
Not to derail, but how are you uploading your video to YouTube with a copyrighted song from Coldplay without getting flagged?  I tried to do that the other day and video was instantly removed
2017-6-6
Xman1
fansbab5d456 Posted at 2017-6-6 19:14
I think you are allowed a certain time frame.  Also, the sounds are too generic to positively place.
2017-6-6
Xman1
Lucas775 Posted at 2017-6-6 18:39
Well thanks.
2017-6-6
12Next >
