Tom_A
Flight distance : 899951 ft
AntDX316 Posted at 6-8 22:10
I used to just manual but now I just hands-off RTH and then manual 3rd person spot the landing but if I'm looking down w/ the camera and it's not going to hit anything I just do nothing and it's good. If you can't trust your drone, you cannot work properly.
It takes so much time to come down even at 3 or 4m/s. It's boring. The only things you really should be doing when flying is getting to the location safely and setting up the shot. Coming back and landing should be safe with RTH as it stays that altitude and heads back. If you lose connection, I find it traces the flight path it came in and follows it but this happened w/ the Mavic 2 when I flew around the Revel building in Atlantic City and lost connection Instantly. I'm not sure if the P4P V2.0 does the same or the Spark. I don't "test" these systems like that. I couldn't see the Mavic 2 feed for at least 10 seconds. It was scary. The video on the drone showed it where it's going back that way (I thought the compass calibration on part 2 was wrong) and a video showed it would go back the same route. As for the APAS systems, my RTH altitude is always higher than the tallest obstacle between me and it. I always stop to set that up before really heading out.
Agree that the return flight can be boring if there's nothing you want to video on the way back, but hitting the RTH button just makes it more boring. I'm not going to hit RTH and then go have lunch before my drone has landed. I'm still watching to make sure everything works properly, but now I have absolutely nothing to do. I think that the loud beeping (even though you can disable it) indicate that the feature was intended to be a failsafe, not an all done button. |
