Punchbuggy
Flight distance : 483166 ft
Labroides Posted at 2017-6-13 18:15
Yes, the problems that there are conflicts with two apps running at the same time ""
You should NEVER attempt to run two different apps at the same time.
Lab,
A thread is only a waste of space if no-one gets anything out of it. The only thing here is that there seems to be a lot of repeating. So I'll do the same in an attempt to sum up:
The message appearing on start of DJI GO app is a poorly worded message. DJI clearly want the pilot to take responsibility for flying outside of a small recreational space i.e. large heights or distances. It's a 'nag screen'. If you don't want to accept that, then downgrade if that's your choice - the cost may only be an inability to access further updates until you do accept responsibility. In other words, this is Not a Chinese conspiracy, people! DJI are just trying to show some responsibility due to sooo many drone abuses by idiots - with the press using pictures of Phantoms each time they report them...
As Helimage and others have commented - No, you do not need internet connection to click past the nag message (OK, perhaps initially to set the setting - I'm not sure) as it makes no difference in the field. DJI have released a new SDK (I think v4.1) to developers to link into this. I suspect this is optional, but someone can set me straight.
Finally, you should Never run two apps which control your craft at the same time. It's like when my girlfriend is in the passenger seat of the car when I'm driving - only one of us can effectively steer the car, but that won't stop the other trying... |
