MidjCo
DJI Thor Posted at 2017-12-7 23:27
Sounds like something there is a loose connection, is there an impact damage before? At the same time, I had forwarded to the engineers to confirm. Please wait and I will come back here once I hear from our engineers.
As I stated before, the gimbal chattering did not occur until after the firmware update and it starts the exact same chattering upon turning it on. I have checked visible connections and everything appears normal.
This is doing the exact same thing as numerous other issues on the related thread so I would be inclined to try a firmware fix before thinking it is a loose connection.
The longest of the videos, the one where I turn it on, you can hear the chatter and see the cam move slightly upon the positioning. I showed the other video just to emphasize that any movement against the camera should force the gimbal to keep the position but results in the chatter.
I personally do not think it is a loose connection.
Just an FYI: I am an electronics technician and have worked in the electronics engineering field. I have a strong mechanical background also.
There is always the possibly that I am missing something but research points to something in the firmware. So, with that said, can you please help with a firmware fix while the engineering department does their thing?
Thanks,
Joe |
