Gimbal calibration loud buzz &a freezes at 50%
DJI Thor
Flight distance : 13602 ft
fansd080862c Posted at 2018-1-24 12:45
Hi, I have a P4 Pro with exactly the same issue, firmware is updated, need to send it for repair or can be fixed with special firmware/calibration? Regards.
Hi, if the issue persists when your drone is updated to the latest firmware V 01.05.0300, you might need to send it in for repair. Please contact our support to start the case. http://www.dji.com/support
2018-2-5
DJI Thor
fans0996eee4 Posted at 2018-1-24 19:39
HI All,
I'm having the exact same issue with my Phantom Pro 4 Plus, it fails a gimbal calibration at 50% and makes a buzzing noise and drifts to the left. Is this a software thing that I can fix via a different firmware?
Hi, just to verify, have you updated the firmware to the latest version V 01.05.0300? If the gimbal issue persists, you might need to send the drone in. And for the drone drifts, try to calibrate the IMU and change the props. And please help to confirm if the drone crashes before, send the drone in if it has impact damage to the drone. http://www.dji.com/support
2018-2-5
DJI Thor
BrianMNY Posted at 2018-1-27 11:38
Repair facility has the drone under repair at the moment. Case CAS-1402231-D9W1R3
Sorry for the late update, I checked the case number, the drone had shipped back to you. Have you received it? Does everything work fine now?
2018-2-5
sclab
Flight distance : 932 ft
Same issue,
Phantom 4 Advance FW 01.00.0128
Could you send me the firmware.
My email is sc_lab@yahoo.com
2018-2-16
alamphear85
Flight distance : 9672 ft
Hello All, I guess I am not alone in this. Went to take my Phantom 4 Advanced out today and it was doing the same thing, annoying buzzing in the gimbal. Of course, like everyone else if you touch it, it stops, let go it goes back to buzzing and after a few minutes it gets warm. I hear the beta seems to help fix this but I can't find it nor can I see it on the Assistant 2 Software. Can someone help me on this. I can provide a video and images if needed.
2018-2-25
Marek Szuszko
Poland
https://drive.google.com/file/d/ ... 0YN9n6MQ4W-eJv/view
please help me ;(
marek.szuszko@gmail.com
2018-3-1
fansba859e6c
Flight distance : 230 ft
Hello all
I have a phantom 4 pro that when you start the A/C the gimble stays straight and true . As soon as A/C is moved the gimble turns and starts to oscillate left and right, and the gimble calibration stops at 50% and the gimble gets hot. This started after the last update.
I hope the Beta Version can fix my problems. Could you please sent me the file to my account
langsh@comcast.net
Versions
A/C 01.05.0300
Controller 01.04.01.00
precise fly 01.00.01.09
Basic fly 01.00.01.07
Thanks for your help,
Shawn
2018-3-2
djiuser_qc2KM4Lk8W4m
Flight distance : 135033 ft
DJI Thor Posted at 2017-7-19 21:31
Hi all, this is a known issue about the gimbal noise and our engineers are working on it. And now we would like to release a beta firmware to your DJI account to update for this case. Could you leave me your account address? Sorry for the inconvenience and thank you in advance.
Hi Thor, I have the same issue with my gimbal.  My email address is allthatcanbe@hotmail.com
Thanks.
2018-3-3
DJI Thor
sclab Posted at 2018-2-16 09:27
Same issue,
Terribly sorry for the late cover for some reasons. The beta has been forwarded, please check your account and let me know if you haven't received it.
2018-3-3
DJI Thor
Marek Szuszko Posted at 2018-3-1 12:03
https://drive.google.com/file/d/1HzC6mhLW_Gagm7PeQr0YN9n6MQ4W-eJv/view
It seems you are using the Phantom 4 Pro, the issue has been resolved by the latest firmware. Please update the drone to the latest version and see if it works.
2018-3-3
DJI Thor
fansba859e6c Posted at 2018-3-2 08:01
Hello all
Hi Shawn, the gimbal calibration issue had been resolved by the latest firmware. If you had updated to the latest version but the issue persists, you might need to send the drone in for repair, sorry for the difficulties. Please contact our support for a further help: http://www.dji.com/support
2018-3-3
DJI Thor
djiuser_qc2KM4Lk8W4m Posted at 2018-3-3 01:14
Thanks.
Hi there, if you are using the Phantom 4 Pro, the issue has been resolved by the latest firmware. Please update the drone to the latest version and see if it works.
2018-3-3
DJI Thor
alamphear85 Posted at 2018-2-25 15:34
Hi, the beta needed to be sent, please kindly provide me with your DJI email account so I can help to forward it to you. Thank you.
2018-3-3
fans5af88417
Flight distance : 1014216 ft
Same problem... brand new  PH4 Pro 50% gimbal calibration stuck... I've the latest firmware  (01.05.300) and by DJIi assistant I've restored to fabric but nothing change... I can't calibrate gimbal..
2018-3-4
fans5af88417
fans5af88417 Posted at 2018-3-4 06:29
my dji email is alcanale@libero.it
2018-3-5
DJI Thor
Terribly sorry for the late reply. The gimbal issue has been resolved by the latest firmware for Phantom 4 Pro, please update the firmware to the latest version V 01.05.0600. If it doesn't help, please send me a video for further checking.
2018-3-24
danziger80
Sweden
I have the same problem can I have the beta firmwire to henningsson@gmail.com
2018-3-27
kenny koala
I am having the same problem...  Phantom 4 advance.  All works good but has this buzzing from the Gimbal and gets hot. Can i please have the beta version as well. ken.knight@mail.com
2018-3-28
ionescu liviu
Romania
Hi Thor! I have the same problem with a Phantom 4. For the last few months now. Never been crashed, calibrated everything multiple times, updated everytime. The gimbal vibrates, makes a loud buzz and gets hot. It's very frustrating, the videos are unusable and even the pictures are messed up. Can you please send me the beta firmware?  ionescu_liviu_gabriel@yahoo.com
2018-3-29
fansd080862c
Flight distance : 156650 ft
Argentina
Hi Thor, still facing the same issue, can you share beta firmware to check if I can fix with it? tvdigital@gmail.com
Thanks.
2018-4-2
MasonWilke
Hi Im in dire need of this beta on a phantom 4 I just picked up used that needed an update worked fine until this morning awful noise, heats up, and moves slightly. Calibration stops at 50% im running dji assistant 2  with v02.00.0700 and latest firmware on r/c. my dji account email is MasonMichaelWilke@gmail.com PLEASE AND THANK YOU
2018-4-14
DJI Thor
danziger80 Posted at 2018-3-27 00:34
Sorry for the late reply. If you are using the Phantom 4 Pro, please kindly update the drone to the late firmware. The issue has been resolved by the new firmware. If the issue persists, I suggest sending the drone in for repair.
Please contact our support on the following page to start a case: http://www.dji.com/support
2018-4-20
DJI Thor
kenny koala Posted at 2018-3-28 03:16
Sorry for the late reply, Kenny, the beta has been forwarded, please check and update either via DJI GO 4 app or DJI Assistant 2.
2018-4-20
DJI Thor
ionescu liviu Posted at 2018-3-29 10:44
Sorry for the late reply and the difficulties. However, this beta is for Phantom 4 Adv now. If you are using the Phantom 4, and you had tried calibrating the gimbal and refresh the firmware, I suggest sending the drone in for diagnose. Please contact our support on the following page to start a case: http://www.dji.com/support
2018-4-20
DJI Thor
fansd080862c Posted at 2018-4-2 07:23
Thanks.
Sorry for the delayed. May I know which drone you are using? If it is a Phantom 4, please refer to my reply on 904#. Thank you for understanding.
2018-4-20
DJI Thor
MasonWilke Posted at 2018-4-14 13:14
Hi Im in dire need of this beta on a phantom 4 I just picked up used that needed an update worked fine until this morning awful noise, heats up, and moves slightly. Calibration stops at 50% im running dji assistant 2  with v02.00.0700 and latest firmware on r/c. my dji account email is  PLEASE AND THANK YOU
Mason, if it is a Phantom 4, please check my reply on904#. And I had replied your OP. Please kindly check my reply. Thank you.
2018-4-20
Martelli
Flight distance : 218474 ft
Argentina
Hi DJI Thor,
I have the same issue with a Phantom 4 Advanced.
Could you send me the beta update asap please?
... to bertelligustavo@gmail.com.
2018-4-26
DJI Thor
Martelli Posted at 2018-4-26 19:48
Hi DJI Thor,
Roger that, beta sent, please check your account.
2018-4-26
DroneProductions
Flight distance : 399803 ft
Malta
Hi Dji Thor,
I have the same problem with my Dji Phantom 4, the gimbal is making a strange vibrating noise. The noise was there from when I bought it, but now it is affecting the video I am filming too. I have the latest firmware upgrade. Do I need the beta firmware? If yes my email is mark.formosa90@gmail.com.
Thanks
2018-4-28
Martelli
Argentina
DJI Thor Posted at 2018-4-26 22:26
Hello,
sorry I didn't get any email at bertelligustavo@gamail.com
Please re-sent, and send it also to carrifabiola@gmail.com
Thanks
2018-4-28
fans192b13a3
I am having this issue as well and have not been able to fly since the last update.  May I be added to the list as well?  michaelrmarten@gmail.com  Phantom 4 Pro +
2018-5-9
Alejandro O‘Reilly Attolini
Flight distance : 459619 ft
Hello DJI Thor,
Can you add me to the list of the beta version for the gimbal noise issue, please?
oreilini22@gmail.com
2018-5-27
helioguerra
Flight distance : 133376 ft
Brazil
Hi @DJI Thor
Same problem here with PH4 Advanced (last firm)
Gimbal stucked at 50%
heliozinhow@gmail.com
2018-5-30
david_eberhardt
Flight distance : 51486 ft
I just received a new Phantom 4 Pro today and been setting things up. I updated firmware to V 01.05.0600 and associated databases. I also decided to do a gimbal calibration and it seemed to hang on 50%. I turned off the aircraft and controller and Go 4 App (V4.2.16). Restarted everything in proper sequence and attempted to calibrate the gimbal once again. This time it worked. I did NOT hear any noise when it hung at 50% the first time. This may not help those experiencing a problem as mentioned above however it does not seem to be a firmware problem.
I will be wrapping it in bubble wrap and launching my first test flight tomorrow.
2018-5-30
joaobraga
Flight distance : 2493110 ft
Portugal
Please, i have the same problem. I downgraded to .0300 to see if it works.
2018-6-7
Jimmy hoffa
Flight distance : 1824291 ft
Why downgrade?.... the fix is in the new firmware also try to calibrate on a level surface....
2018-6-7
joaobraga
Portugal
Jimmy hoffa Posted at 2018-6-7 07:39
Because i have the problem with the .0600
2018-6-7
joaobraga
Portugal
joaobraga Posted at 2018-6-7 07:54
And get stuck on 50% on calibration the gimbal. The jello effect is amazing.
2018-6-7
KedDK
Flight distance : 1133038 ft
Denmark
joaobraga Posted at 2018-6-7 07:57
I am afraid the solution in #881 would count your case too.
2018-6-7
djiuser_s7lb5w3T1kXh
Flight distance : 3114022 ft
KedDK Posted at 2018-6-7 23:51
Hi DJI Thor,
2018-6-12
