Is this normal for gimbal
922 11 2017-6-17
StephenGSY
Flight distance : 814232 ft
Jersey
Is it normal for gimbal to do this only in sports mode. I’ve not noticed it before so maybe it is. When at full throttle. It seems to pan down a little. And appears normal.
2017-6-17
Mcflying
Flight distance : 243753 ft
Hi StephenGSY,
I think you missed some words or forgot to add some footage.
Cause i cannot make chocolate from your post
2017-6-17
StephenGSY
Guernsey
Hopefully it uploads now
2017-6-17
StephenGSY
Guernsey
Mcflying Posted at 2017-6-17 12:40
Hi StephenGSY,
Realised mobile won’t send it it’s up now.
2017-6-17
Mcflying
If you mean the hobble on de 27 sec time that is normal and nothing to worry about.
2017-6-17
WolfgangStiller
Flight distance : 599416 ft
Nothing there yet.
2017-6-17
RCNJ
Flight distance : 114665 ft
Gimbal shouldn't drop like that without you doing it, check it is seated properly under the catches at the front 2 sides and middle rear, if it is already it looks like a problem to me....
2017-6-17
Gallacherboy
Flight distance : 778209 ft
That also happens when I fly in both SPORT and normal mode. I have not flown in a while and will test with the new Firmware and see if it drops again.
2017-6-17
StephenGSY
Guernsey
Mcflying Posted at 2017-6-17 13:07
I mean the noticeable dip in the camera when start to go forward in sport mode. The first few seconds of the video are P-Mode with no dip occurring. I then switch to sports mode, then it dips I manually put pan gimbal upwards to centre. Then forward thrust in sports mode again and it dips.
2017-6-17
StephenGSY
Guernsey
It actually move -7 degrees downwards.
2017-6-17
StephenGSY
Guernsey
I’ve checked the gimbal is seated. It don’t do it in normal mode. Only Sports mode. Maybe I’ve just never noticed it before. It drops just enough to stop Props showing in video. Maybe it’s supposed to do that.
2017-6-17
Mcflying
Well, whenever i fly in sportsmode my gimbal does not do that.
So short answer, no it's not normal
2017-6-18
