Punchbuggy
Flight distance : 483166 ft
The red/green flashing LED on controller is telling you that a firmware update is required. I'd say that you've updated the firmware on the P4P, but not the RC successfully.
I suggest you connect your craft to computer and use Assistant 2 to refresh your firmware.. Then turn on your RC with tablet attached - on the 'splash screen' when it would normally display 'getting version details...' it should show you a firmware is available message (from memory). The RC LED should be blinking red/green too. Do that, then power-cycle your RC.
Then manually re-link both. Instruction here at post #7: http://forum.dji.com/thread-94069-1-1.html
