crc2004
Flight distance : 63461 ft
That's the point. Would you rather your P2V+ be totally lost or have it return to a less accurate position?
the following is from http://www.maptoaster.com/maptoaster-topo-nz/articles/how-gps-works/how-gps-works.html
If the GPS receiver is only able to get signals from 3 satellites, you can still get your position, but it will be less accurate. As we noted above, the GPS receiver needs 4 satellites to work out your position in 3-dimensions. If only 3 satellites are available, the GPS receiver can get an approximate position by making the assumption that you are at mean sea level. If you really are at mean sea level, the position will be reasonably accurate. However if you are in the mountains, the 2-D fix could be hundreds of metres off. |
