fans4b62ed86
Flight distance : 316545 ft
RicardoGray Posted at 2017-6-20 06:05
I keep this site on my list of places to look for really good information. DJI can sometimes be hard to find what you want or need, especially since some of the products are being discontinued or no longer sold. Try this site.http://www.phantomhelp.com/Phantom-3-Advanced/
They have everything from software to firmware and everything in between. Older versions to the latest releases and for many different models. Remember, the firmware has both the software for the aircraft and your RC combined into the one file. It is not one for each. And to be clear, if you download the firmware, depending on which version you are on, you can put the bin file on your sd-card and update your aircraft, but the RC gets upgraded through the app via your WiFi. That is how it is supposed to work if all goes well. Of course if you are having troubles, you can use the USB drive with your sd-card to upgrade your RC too.
Thanks for that.
However, I havent upgraded for some years now, still on 1.4.
Im led to believe that with the new upgrade you have to 'register' before each flight - is that correct?.
At the moment, I just assemble and fly, no messing about. Of course its still geofenced and I cant fly in restricted areas, but apart from that, trouble free flying, has it changed?.
Buzz |
