Stuttering feed
1066 10 2017-6-20
fansba5a3e57
I thought I would share an experience. My Spark and my iPhone communicated just fine, as soon as I connected via my RC it was unusable, the video stream was giving me maybe 1/2 a frame per 20'seconds. I tried all sorts to no avail but today I tried connecting via wifi to my RC after switching off my Bluetooth, it works just great! So my Apple Watch was breaking my Drone, oh the joys of IT....
2017-6-20
Maxi3D
Flight distance : 307621 ft
Or you can connect your phone to the RC with a mini USB adapter.
2017-6-20
GCBrent
Flight distance : 66286 ft
Yep this has been reported numerous times! Switch off Bluetooth when flying and all will be well. Seems to cause interference somehow.
2017-6-20
fans1a9af154
Flight distance : 57287 ft
Maxi3D Posted at 2017-6-20 12:54
Will connecting via a mini USB adapter help prolong the life of the iPhone battery rather than via Wifi. I find my iPhone 7 battery drains almost as quickly as flying the spark.
2017-6-21
fans1a9af154
GCBrent Posted at 2017-6-20 14:58
Ahhh ok, I will try that tomorrow. I had a situation where my feed freezes, goes black and white and I can honestly say, gave me a small heart attack as the drone was almost out of sight some 50-70m away.
If this is so critical, DJI should ideally create a pop up reminder to turn off Bluetooth when you connect.
Thanks
2017-6-21
la_panza
Flight distance : 1123133 ft
interesting, do you mean if I connect the phone to the RC's USB port I can skip the WiFi link between the RC and the phone, similar as we use to do vith the mavic?
so I need a cable with one end terminating MALE micro-USB and the other end  terminating MALE "lightning"  (Apple)..  is it correct?  and where can I get this cable?
2017-6-21
Thor1
Flight distance : 196837 ft
la_panza Posted at 2017-6-21 03:06
https://www.amazon.com/gp/produc ... 00?ie=UTF8&th=1
2017-6-21
fansba5a3e57
Thor1 Posted at 2017-6-21 03:07
https://www.amazon.com/gp/product/B00N9S9Z0G/ref=oh_aui_detailpage_o00_s00?ie=UTF8&th=1
Hmm, when I first had this problem I tried the cable solution, it did not connect at all! I will try again!
2017-6-21
Maxi3D
fans1a9af154 Posted at 2017-6-21 00:06
I don't think the RC has enough power to recharge the phone. Some say this trick won't works with iPhone 7.
2017-6-21
fansba5a3e57
Maxi3D Posted at 2017-6-21 05:25
Ah! My iPhone is a 7 so that is probably why it doesn't work.
2017-6-21
fans8c349a91
Switching off Bluetooth worked for me. Hopefully this is just a bug!
2017-6-22
