Where is flight controller Serial.
92361 17 2017-6-22
Protonix
Im trying to unlock a yellow zone and it wants my controllor serial.  I go the about tag and it's blank?  Which number on the back of the controller is ther serial number.   There is a lot of numbers.
2017-6-22
RichJ53
Flight distance : 1837356 ft
When you are connected to the Go 4 App with the remote and Spark. Enter the device home page go to the general settings page with the three dots ...   top right of the page view.
go to the bottom of the list, tap the About and the SN is shown.
Rich
2017-6-22
djiuser_ibEsCan
I have the same issue, I have a crew on site and need to unlock an area but there are is no Serieal Number.
2017-7-6
fanale
I have followed the instructions above and SN is noted as N/A????
2017-12-21
jksphoto
Flight distance : 114121 ft
fanale Posted at 2017-12-21 12:10
Are you running an OTG cable. Given the issues this is causing currently, I would try connecting without to see if the makes a difference.
2017-12-21
bdullea
Flight distance : 88786 ft
Serial by default is 123456. It’s the 6 digit number located on the bottom of the controller usually last set of numbers near bottom of the controller.
2017-12-21
enriz
Paraguay
You need to have the aircraft on and then it will appear...
2019-4-11
enriz
Paraguay
djiuser_ibEsCan Posted at 2017-7-6 10:14
2019-4-11
FlyingV
enriz Posted at 4-11 12:24
This is completely absurd to require to have the aircraft on, when the information we need is stored in teh controller only
2019-4-16
djiuser_YmcNwR5HoIej
I'm using an Android tablet.  What S/N do I use?
2019-6-19
jason_rmh
Flight distance : 6674222 ft
On my mavic pro, the serial number listed in the DJI Go4 app was not printed anywhere on the controller itself.I believe the serial is for the FLIGHT controller, not the actual hand held controller.
The serial is a 14 digit string consisting of numbers and letters.
eg 01ABCDEF01234X
The steps are the same for iOS and Android:
  • Turn on the drone, connect the controller & phone / tablet.
  • Open DJI Go4 app
  • Enter device
  • Press 3 dots ... in top right corner to open general settings
  • Select 3 dots ... from menu then 'About'
  • In the About screen you will the serial number
In IOS its called 'Flight Controller Serial Number'.
In Android its called 'Flight Controller SN'.
Thanks
Jason
2019-6-24
renebenas
Guam
163DG1S001Q945
2019-7-27
Dimitrios M
Flight distance : 754705 ft
That means that you haven't turn on your drone. Both the drone and the RC must be turned on
2019-9-30
Ben Mason
Flight distance : 610614 ft
The flight controller is inside the drone, so it makes sense you need to turn it on to check it, the other way is to open up your drone and there should be a serial number sticker stuck to the flight control board, but doing that would void your warranty.
2019-10-1
djiuser_u0ppBRQiMP3y
Absolutely ridiculous process to find a serial number.  Absurd.  Oh and I have the Mavic Mini, which conveniently isn't one of the drone choices in the Go 4 app.  Awesome.  Well done team.  Still haven't located this thing btw. #
2020-7-3
djiuser_pkAcW3dqmCAc
Flight distance : 26936 ft
Anyone can help where is serial number on dji mini 2
2021-3-18
Dave Sawyer
I had trouble getting the fc serial. The instructions to use .../about didn't work because there was no such menu. Turns out I'm on Android and the DJI app in the play store is fake. Using the same icon, etc. Make sure you get the app from DJI.com and not the play store
2023-8-13
DJI Paladin
Flight distance : 318 ft
Dave Sawyer Posted at 8-13 08:00
Hi, Dave. We're sorry if you experience trouble regarding this. We highly recommend our customers download the DJI app straight to our website to avoid any issues. To download the official DJI app, you may access the link below. Please feel free to contact us if you have any inquiries or concerns. Thank you for your valued support.
https://www.dji.com/downloads
2023-8-26
