Punchbuggy
Flight distance : 483166 ft
Just to add to what Aardvark was suggesting, an earlier version of Assistant 2 (v1.1.0, I think) included an 'unsigned' USB driver which wasn't installed properly as a result - you needed to run the installation with driver enforcement off to get it onto your PC. I believe subsequent versions were supposed to resolve this. You could try that as a last option - costs you nothing to try.
Windows 10 enforces driver signatures by default. This can be disabled to install drivers that are not digitally signed. Use the following steps to disable driver signature enforcement.
1.Click the Start menu and select Settings.
2.Click Update and Security.
3.Click on Recovery.
4.Click Restart now under Advanced Startup.
5.Click Troubleshoot.
6.Click Advanced options.
7.Click Startup Settings.
8.Click on Restart.
9.On the Startup Settings screen press 7 or F7 to disable driver signature enforcement.
Your computer will restart and you will be able to install non-digitally signed drivers (in this case, to successfully run the DJI Assistant 2 installation). If you restart your computer again the driver signature enforcement will be re-enabled.
