Spark RC Change SSID and Password
36054 34 2017-6-29
fans0ef707ed
Singapore
Hi,
I will like to check whether can I change the SSID and Password of the spark controller ?
Thanks.
2017-6-29
Jack_Sweeney
Flight distance : 634692 ft
Yep right in the DJIGO4 App
2017-6-29
fans0ef707ed
Singapore
I did went to the DJIGO4 app to change it but couldn't. Is it because I connected to the RC?
2017-6-29
Michael Miami S
Flight distance : 24199 ft
I have the same question. When Im in the Wifi settings, I can't seem to change the SSID for the remote. The aircraft SSID was easy to change. But I need to change the Remote SSID name since thats the one I have to connect my phone to every time. help please. When I press the SSID name in the settings nothing happens.
2017-6-29
Jack_Sweeney
I might be wrong it might be the sparks WIFI that you can change and not the Remote controller check out this https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=video&cd=1&cad=rja&uact=8&ved=0ahUKEwi5qILFtuPUAhXBKyYKHWkVB0AQtwIIJDAA&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DPMm2UZd5W3U&usg=AFQjCNEZdHw2HCqS0gMSOfOVBkyJ1xGt_w
2017-6-29
Jack_Sweeney
Jack_Sweeney Posted at 2017-6-29 07:58
I might be wrong it might be the sparks WIFI that you can change and not the Remote controller check out this Youtube DJI Tutorials Linking Spark
Wrong Link
2017-6-29
fans04932e4b
Flight distance : 149613 ft
From what i understand you are not able to change SSID or password from the RC. You can only change SSID and password from the direct connection to the drone.
2017-6-29
fans0ef707ed
Singapore
fans04932e4b Posted at 2017-6-29 12:29
You can change the RC SSID and password. Someone share the process by connecting spark, rc and android mobile. Not entering the camera view but at the main menu, click on the remote connect icon bottom left which you can change it there.
I changed mine already.
Happy flying !
2017-7-1
Jack_Sweeney
fans0ef707ed Posted at 2017-7-1 19:19
I've been told directly by customer support  that you can only change drone ssid and not rc. If you could show how you do please do so.
2017-7-11
MAVICDLNM
Flight distance : 10696686 ft
How you did that?  I get to the same screen but it only show the aircraft wifi name and password that can be change.  Is it because I use iPhone not android?
2017-7-13
MAVICDLNM
Jack_Sweeney Posted at 2017-7-11 18:01
Thats what i was told too.  But the RC password is same for all, so would that be really dangerous if anyone try to hack it?
2017-7-13
rickysuperdog
Flight distance : 929429 ft
I changed the RC password from day one I received the Combo, using the above steps
2017-7-13
eylneb
Flight distance : 122477 ft
Malaysia
I don't think you can change the RC SSID n pass... only for Spark
2017-7-14
spyark
Singapore
I just got my RC today, and FYI. You can change the default RC ssid and password.
1. Connect to the RC via default wifi
2. Launch the DJI GO APP
3. Click on the 'RC connected', just beside where we have the 'GO FLY' or 'Connect Device' button.
4. Make sure you are on the mobile device tab at the top, Click on reset aircraft wifi settings at the bottom.
Basically, the confusion here is because it still says 'reset aircraft wifi settings' instead of 'reset RC wifi settings'. So when connected to the RC, the RC is the 'aircraft'.
After that just restart the RC. Voila! New SSID and Password, not 12341234 ...
2017-7-18
rickysuperdog
eylneb Posted at 2017-7-14 00:24
Yes you can, within this firmware and Go4 version 4.1.3. System: Only Android can change the RC password
2017-7-18
eylneb
Malaysia
rickysuperdog Posted at 2017-7-18 05:30
Thx for the info..
2017-7-18
Jack_Sweeney
spyark Posted at 2017-7-18 04:54
I can confirm this works but the it will only work when Spark is also connected to the controller
2017-7-18
eylneb
Malaysia
interesting..
just in case if your remote doesn't work
https://forum.dji.com/forum.php? ... &fromuid=853829
2017-7-20
fans4793942d
Confirmed, RC SSID and password can only change using Android device.
2017-7-27
Zviratko
Flight distance : 1401 ft
Czechia
Thankfully, the information in this thread is _NOT_ correct and you _CAN_ change the RC SSID and Password (even on iOS)
What you need to do (or rather what I did) was to connect via Wifi to the RC controller without the Spark switched on. Then open DJI GO4 on iOS -> Enter Device -> Settings -> Wi-Fi Settings and you can click on and change both SSID and Password from here.
It didn't work for me before, probably because Spark was connected, but this worked flawlessly.
2017-8-14
premium
Flight distance : 2300 ft
Indonesia
yes it is possible to change rc name and password
2017-8-18
elsonsiquara
Brazil
How to find out the password of the remote control once the device label has been erased?
2017-9-24
PangMang
Flight distance : 40279 ft
You can, just found it, connect Spark, controller and phone, go to wifi settings in the app and the controller settings are at the bottom of the list
2017-12-15
fans568f2523
Flight distance : 89203 ft
+1
I can confirm connect via RC (with spark powered off) to change SSID info of the RC. Connect direct to Spark to change SSID info of the Spark.
As above enter the camera view without connection to aircraft, hit setting WIFI and amend to your hearts content.
If you are connecting direct to drone then clearly you will have aircraft connection but the procedure is the same from camera view.
2018-1-15
Bayguy69
Flight distance : 944275 ft
Puerto Rico
That's not correct. I have an IOS Device and I just change the RC ssid and password.
2018-1-15
rickysuperdog
Bayguy69 Posted at 2018-1-15 03:57
You see my post was posted on last year July... every informations will be outdated.
2018-1-15
Bayguy69
Puerto Rico
rickysuperdog Posted at 2018-1-15 22:21
I realize that the second I place my comment. Sorry.
2018-1-16
Frunobulax
Flight distance : 12936 ft
like Pang Mang says, DIJGO app , camera view, then the dots top right, will not see the wireless connection unless you are connected to the spark and RC controller
2018-12-21
djiuser_NCXRokNslVsT
Flight distance : 163619 ft
I have changed my password for the RC. That is fine.
However, how do I change the WiFi password for the spark?
My concern is, can someone hijack the Spark, while it is onflight, by them getting the Factory WiFi password?
I would think I need to cahnge both passwords to be protected???
2018-12-25
Doc Ozzy
Flight distance : 2174482 ft
Thank you for the helpful information.
2019-4-2
Sidesumi
Flight distance : 61470 ft
I have the inspire one and my controller is asking for a name and a code and I cannot find those does anybody have some advice on how to get the controller name and code so that I can connect my controller to the drone?   And thank you very much for your help guys
2019-7-5
briarphotos
Not sure what your working with, but on my iPhone Go 4 App there are no 'tabs' to choose from when you click the RC Connected........just takes you to a flight info screen.  I've tried to reset RC wifi password with the aircraft on and off, with Go To cable connected and disconnected and a/c on and off.........all I get is Change Password - Cancel or OK and when I choose OK nothing happens, just goes back to the menu screen............
2019-9-1
briarphotos
Zviratko Posted at 2017-8-14 20:57
Uh, what version of this stuff are you using........the latest Go 4 app has no such option........when I Enter Device I get three choices:  Activate, Connect to Aircraft, or Enter Camera View.......there is no such option as Settings to choose!
2019-9-1
S-e-ven
Flight distance : 5910961 ft
Thailand
briarphotos Posted at 9-1 11:29
Oh:
Connect to aircraft!
You need to change this in the settings connected to RC , RC connected to the Spark.
But still, I am on android. So ....!
2019-9-1
briarphotos
S-e-ven Posted at 9-1 23:05
Oh:
Ok, thanks............will give it a go for both the aircraft and the RC and keep fingers crossed.
Bill
2019-9-5
