Memory card for X3
Diarmuid
Flight distance : 749094 ft
Hi Guys,
Im only new on here. I had a Phantom 3 Advanced and I upgraded to the Inspire 1 v2 with a X3 camera. I just wanted to know if there is a particular Micro SD card i should be using to get the best fooatge.
Also how do i ad in what equipment i have under my avatar as i have a few DJI products
2017-6-29
Highasakite
Flight distance : 1423930 ft
Diarmuid, Welcome! You may be able to use the card you have, if not you can find plenty of disagreement on which card is the best card... but 64MB is the largest one you can use in the X3. As far as equipment is concerned, if you registered them, or if you upload your flight records in the GO app, your equipment should automatically show. Safety First! Ken.
2017-6-29
Diarmuid
Highasakite Posted at 2017-6-29 12:23
Thanks Ken,
The card i have is a Kingston 32GB Micro SDHC Class 10 U3Ill get to the app and try sync them up.
2017-6-29
Bradders
Flight distance : 862283 ft
I do not own a Inspire however frequently read this side of the forums and would recommend this micro SD card to you, http://amzn.to/2s82HTb It is one of the fastest memory cards available and is a reasonable price it is also made for 4K recording
2017-6-29
Diarmuid
Bradders Posted at 2017-6-29 22:58
Thanks i mill Bradders
2017-7-1
DronesIntegrate
Flight distance : 683720 ft
The higher write speed, the better.  I use a 90 mb/s write card; size doesn't matter. Anything 60mb/s and above is generally pretty good. I have the 32gb version of the link above, btw.
2017-7-1
Diarmuid
DronesIntegrate Posted at 2017-7-1 07:50
Good to know.
Thanks
2017-7-1
