DJI Inspire1 6pack gang charger
12Next >
7746 44 2015-3-17
dundee
Flight distance : 33550 ft
Thailand
2015-3-17
gareth.greener
Flight distance : 366201 ft
Very cool idea. Make sure you have a fire extinguisher nearby just incase.
2015-3-17
dundee
Thailand
gareth.greener Posted at 2015-3-17 21:00
fire extinguishers don't realy work on lipo's
2015-3-17
rodger
Flight distance : 20145135 ft
Dundee, is this a product made by DJI?
Thanks
2015-3-17
dundee
Thailand
rodger Posted at 2015-3-17 22:03
Thanks
Nope, it's not.
But the box contains 6 DJI stock power-supplies and 6 DJI TB48 batteries.
My prototype
Working on : 8pack
                   Batteries holsters in 3D print (6pack model with aluminium frame)
                   Build in inverter (12/24v DC -> 220v AC)
2015-3-17
flynamics
you make another! I will buy one from you!?
2015-3-17
apjr1
very nice I would keep my eyes on it while charging or away from your house !
2015-3-17
dundee
Thailand
apjr1@verizon.n Posted at 2015-3-17 23:46
Temperature sensor (if to high inside) will cut all power.
There is also a 110/220v. 10amp fuse build in.
If its not a problem to put all these batts in the stock case, then for sure
not a problem to keep them in this box.
2015-3-17
InspiredOne
Nice job on building that case!
However, my attorney is preparing to file a law suit for the mental distress and emotional anguish I've suffered as a result of not being able to get that annoying ditty you used in the video out of my mind. It's driving me nuts!
2015-3-17
gds3d
Flight distance : 29646 ft
I started to make one using leggos.  It needs more work but yours looks much better.  Is that a dremel case?  It looks like mine.
2015-3-17
dundee
Thailand
InspiredOne Posted at 2015-3-18 01:49
However, my attorney is preparing to file a law suit for the mental ...
haha, i know what you are talking about
2015-3-17
Outta Control
Flight distance : 779419 ft
Very nice. Now you got me thinking.
2015-3-17
apjr1
this is how i keep my away from my real toys in my garage
2015-3-17
Grimtheviking
Flight distance : 11796312 ft
Dundee, that Spanish worker in China is absolutely brilliant mate, I just cannot stop laughing at it... and I own an Inspire1,,
2015-3-17
DJK
Flight distance : 44154 ft
Nice flight box. I can see how everything but the battery holder insert is built. where did you get the internal frame and connectors? Was this rebuilt from another charging unit?
2015-3-17
RichJ53
Flight distance : 1837356 ft
Nice job Dundee!! I like it very much.
Can you provide a parts list to duplicate the box? Or maybe you would like to build me one   less the chargers  LOL
2015-3-17
dundee
Thailand
Grimtheviking Posted at 2015-3-18 06:38
Dundee, that Spanish worker in China is absolutely brilliant mate, I just cannot stop laughing at it ...
I have another one coming in a few days
2015-3-17
dundee
Thailand
Blueprint-1
2015-3-18
rodger
dundee Posted at 2015-3-17 22:20
Nope, it's not.
My proto ...
Great job! Very inventive. Good deal on the Protection and control of heat issues. Please keep us posted on how it works out for you. I for one would be interested in your progress.
2015-3-18
dundee
Thailand
Good airflow between all components.
Actualy the batteries feel cooler after charging.
Also the stock power supplies feel cooler then before.
Good quality fan is a must here
2015-3-18
rodger
dundee Posted at 2015-3-18 21:05
Also the  ...
I agree. I use to work on high power radio repeaters and heat is the largest enemy of electronics. If it does get a bit to warm you could also add a heat sink to the chargers and let that disapate the heat by moving the out side air over the heat sink. You should be good though as you are not dumping the fuse. Again nice job. I am impressed.
2015-3-18
DJK
Considering the recent aviation incident, how could you make the box more Lipo fire resistant. Have you considered adding a small heat activated halon or less expensive CO2 cylinder.
2015-3-18
dundee
Thailand
DJK Posted at 2015-3-18 21:56
Considering the recent aviation incident, how could you make the box more Lipo fire resistant. Have ...
This box was not made with the idea to fly.
For that i would use pelican grade box.
2015-3-18
dundee
Thailand
Im considering some stainless steel plates attached to the inside
of the box. Like a bunker.
But then the weight would go up alot.
A fully loaded 6pack is about 8.5kilo or +/-17pounds
2015-3-18
DJK
Maybe consider two models. The field model, and the travel model. I think there is a market considering the potential for stricter requirements.
2015-3-18
DJK
You could also consider some light weight micarta, I think it has a very high temperature rating.
2015-3-18
dundee
Thailand
DJK Posted at 2015-3-19 06:29
will look into that. thanks for the feedback
2015-3-18
wtaylor
Very nice idea.  How did you attach the batter connectors to the little brackets?  Was it just with double sided tape or something better?  Since these are "intelligent batteries" and it is recommended that you remove the batteries soon after charging did you ever think of putting an inline switch (maybe cut the power feed cable to each charger) beside each battery so you can only charge X of the 6 batteries and still use this to store the ones not being used?
2015-3-18
Dangair
Dundee, use a metal box. At least if you burst a cell and catch fire it will contain the heat better. The plastic container will not only combust but will act as fuel. Just a thought. Also, 6 batteries @ 120 watts is darn near 720 watts of power! A good portion of that will be lost through the power supplies, I like what you did there and created space between the batteries, but I would double the fans on the box. And think about putting one in the lid pulling heat out the top. As well, it has been suggested that the metal box and its contents be placed on concrete in a garage away from flammable materials. While this sounds like overkill, these batteries have a tremendous amount of jam. You can weld with them. The battery catching fire on the airplane is a good example. But let's face it, how many of us sit there and watch our batteries charge? One other consideration is if you do get a fire in the box there is a big possibility that all the batteries will be destroyed. If you are talking 6- 5700 mah @ $250 Canadian that's a very smelly $1500 fire. Might be better to reduce the risk to a 3 bay or 2 even ?
2015-3-18
dundee
Thailand
wtaylor Posted at 2015-3-19 15:09
Very nice idea.  How did you attach the batter connectors to the little brackets?  Was it just with  ...
Temporary with double sided tape.
In my new model the connector will be embedded in the 3D-printed holster
together with a on/off switch.
2015-3-19
DJK
An old ammo can might hold three or four, but you might have to open up the chargers and add a cooling fan...probably not for traveling on the airlines.
2015-3-19
rsghowellnj
Flight distance : 508255 ft
Dundee .... when do you begin to start selling this design.  Very sweet.  I'm interested if you decide to sell.
2015-3-19
RichJ53
dundee Posted at 2015-3-18 12:32
Dundee,
Can you offer a three pack?  and sell us your parts list and drawing? At this point I only have three power supplies (DJI chargers)
2015-3-19
dundee
Thailand
Another good tip for your batteries !
2015-3-27
Colonel Angus
Dundee this is about the coolest thing I've seen here yet. Hoping all build one of these neat charging boxes!
The individuals here are so creative it just blows my mind sometimes.
Definately heading to home depot next week to try and follow your lead on this charger box asap ...Bravo Suh!
2015-3-27
dundee
Thailand
Colonel Angus Posted at 2015-3-28 10:28
Dundee this is about the coolest thing I've seen here yet. Hoping all build one of these neat chargi ...
A few ideas to get you started.
1) Look for a good quality strong toolbox. (Check hinges mechanism for good quality)
2) Make sure the box is big enough to ensure good airflow inside (Cooling)
3) Look for a good quality ventilator.
4) Provide an extra air inlet, in case the toolbox cover is closed during charging.
5) Put in a 10amp fuse for protection.
6) if you plan to construct a frame inside the box, go for aluminium profiles.
    Note : My 6pack fully loaded weighs about 8.5/kg - 17ponds with alu frame.
7) Do not under estimate this build !
I'm working on a second model (First is a prototype)
This model will be modular build up.
Im working on a 3D print holster for the battery.
1 holster will contain the batt plug, cables integrated in the holster.
Holsters can be snapped together to form a 2/3 up to 8 gangcharger.
Stand alone temp/sensor (set at 70celcius) with small buzzer build in. (safety)
10amp fuse change to automatic fuse. (safety)
Build in timer/switch. (Set to for example 80minutes, then switch off main power to the toolbox)
Next week i post a video on this forum on the design of the 3D print holster.
2015-3-27
Colonel Angus
dundee Posted at 2015-3-28 11:03
1) Look for a good quality s ...
Just printed off that list and this weekend will go shoppin TY Dudee!!
Some assembly required I see )
Bravo sir on this device Im on it like white on rice.
2015-3-27
Colonel Angus
2015-3-27
dundee
Thailand
Colonel Angus Posted at 2015-3-28 11:07
Some assembly required I see  ...
Haha, just see it, 'white on rice',
2015-3-28
Heliflo
Flight distance : 8885013 ft
Switzerland
good idea, but i see two Points:
-before spending the Money for 6 DJI power supply's I would go for this solution (If anyway all 6 supply's in the same box):
http://www.troybuiltmodels.com/items/HSPSEPOWERBOX050.html
This Powersupply coasts less than 6 original DJI supplys and delivers more than double of the power (1200W instead of 6x80=480W)
-The Ventilator would make much more sense if there also would be a air intake/outtake - or is it designed to leave the box open anyway during charching?
However, a great idea to Charge your batteries for a appropriate amount of Money.... Cheers
2015-3-30
12Next >
