Loosing signal + no image
641 3 2017-6-30
French Spark HK
I plugged my iPhone to the controller but at 50m the image connection starts to be poor and the video is very bad like frozen image then no more image connection !
Anyone with the same issue ?
2017-6-30
Tony Q
Flight distance : 196870 ft
try turning of blue tooth on your phone - i know if i have forgotten to turn bluetooth of because of the same problem as you describe
2017-6-30
Angcharlie
Flight distance : 7257 ft
Indonesia
Tony Q Posted at 2017-6-30 02:45
Hai
Im already turn off the bouetooth and then airplane mode
And even try change to 2.4ghz
But still cannot get the best range, high atti only 20m and lose signal -_-
Any suggest what i must to do ?
2017-6-30
French Spark HK
Same problem here, got 60-90m at best then loosing connection, very scary to fly with no images.
I tried the OTG cable but still doesn't work
I'm unable to change the wifi to 2.4ghz
2017-7-2
