Activation problem
621 6 2017-6-30
Carlos64
Hi...my name is Gianpietro form italy
i recived spark but i have a problem with qr activation code...always error..
anyone know the solution ??
tks
2017-6-30
Carlos64
i made the wifi reset and now my phone S8 found Sperk wifi.. Now I'm doing the firmware update
2017-6-30
DJI Natalia
Super Moderator
Flight distance : 318 ft
Just to verify, all are working properly, right?
Hope you enjoy flying!
2017-7-1
fans0ef707ed
Singapore
Well you can just connect to spark wifi to activate it.
By turning on spark, and afterwhich hold until you hear 2 beeps sound. The SSID of spark will appear on your wifi list.
Initially, I got problem activating it by scanning the QR code too. Happy flying !!
2017-7-1
Angelo26
Flight distance : 799718 ft
Austria
fans0ef707ed Posted at 2017-7-1 01:41
Didn´t work on mine repeatedly ..................{:4_154:}
2017-7-1
Tviscomi
Flight distance : 106699 ft
DJI should just release a freaking statement saying that the QR activation method is "non-functional".  I have yet to seen anyone that has been successful using it.  I own 2 Sparks and it failed on  both.
2017-7-1
fans0ef707ed
Singapore
Angelo26 Posted at 2017-7-1 02:21
Which process did it fail you ?
When you on the spark, then hold down to hear 2 beeps than release. Did this works?
Aftewhich on your mobile, turn on wifi, should be able to see the spark SSID. If your wifi auto connect to other wifi than you have to manually select the spark wifi.
I believe you should able to see the spark wifi.
2017-7-1
