Angelo26
Flight distance : 799718 ft
Austria
Yesterday I received my Spark Fly more Combo and 2hrs ago I wanted to set it up. As Mavic Pro owner with 24 hours + netto flight time and 200 km + flight distance constantly fighting with crashing DJIGO4 (it worked perfect with old DJIGO) I thought DJI learned from it´s mistakes.
I WAS WRONG !
Unpacked the Spark, charged controller and batts of Spark and fired up DJI GO 4 on my (DJI says: compatible) Note 4.
Following the setup-procedure PAINSTAKINGLY I tried to scan the QR-Code on transport - box: it failed
Tried to scan QR-code in Spark batt-compartment: it failed again telling me the QR-code was not recognized
The I tried to transmit Serial Number, typed it in correctly pushed "SEND" and DJO GO4 (latest version) told me "connect to internet" although I was connected to internet all the time.
tried it 10-12 times and always failed.
Tried the same procedures with my wife´s Note 4: failed the same, with same error messages
Tried the same procedure with my Xperia Z Ultra (which is my main phone for MavicPro, although DJI GO 4 crashes on it almost as often as my Note 4). So no activation possible this way.
Fired up Spark to connect to the phone via Sparks WLAN, and guess what, after repeated searching for new WLANs both on 2,4 and 5 GhZ-band with ALL THREE smartphones Spark-SSID did not even show up as new available WLAN.
NOW I am totally fed up with DJI and will send the Spark back for full refund. I am tired to play test-pilot for DJI..... Test-Pilot ? I cannot even start flying the Spark because I can´t even activate it ! Even the most cheap 10 Dollar drones are at least able to present themselves with a detectable WLAN-SSID.
So this is a warning: wait for one year until You buy a Spark, You most probably will get a defective one right now ..........................
