Gimbal Level Problems
924 2 2015-3-17
warren
Flight distance : 1889803 ft
Took the bird up to get a shot of the sunrise this morning.  When pointed at the sunrise, you can see the significant tilt in my image.  When rotating off the sunrise maybe 30 degrees the shot is level.  No significant wind and these are what the images are like when the bird is 'at rest' just hovering up there.  I left the gimbal-guard on once when turning the bird on some time ago but don't think that could have caused it because other than this tilt thing it works fine.
Any help/insight?
Thank you-
Warren
Level
Level
Tilted
Tilted
2015-3-17
flydronefly
I've seen this addressed on the forum before - I have the same problem, but just a very slight tilt - I am able to adjust it with editing. Check out this video, maybe the issue?
2015-3-19
mvpeters
I have tried this fix but the axle on my camera doesn't turn.  I have tried using a pliers and there just isn't any give when I try to turn the rod.  How much effort is needed to accomplish this turn?  I have seen some videos where the operator is able to make the adjustment with just his fingers.  What's up with mine??
2015-6-14
