RichJ53
Flight distance : 1837356 ft
Drone Odyssey Posted at 2017-7-1 20:01
Hi....I had the same problem today after updating the firmware......Was your distance OK?.....my Mavic couldn't go further than 276 feet....and 98 feet altitude. I hope someone in this forum can help.
Sign out of the DJI Go 4 App and then log into your DJI account in the App while connected to the internet. Check all your settings because some of them will return to default values, you will adjust them after the update to suit your preference. See information below:
You only need to do this once after the updates and you do not need to be connected to the internet afterwards.
Rich
DJI Updates Process For Activating Software And Firmware Updates
New Procedure Requires Login After Update; Password Reset Available
This new step, to take effect at the end of next week, ensures you will use the correct set of geospatial information and flight functions for your aircraft, as determined by your geographical location and user profile. All existing flight safety limitations, such as geofencing boundaries and altitude limits, remain the same.
Even if you have registered when activating your aircraft upon purchase, you will have to log in once when you update the new version of DJI GO or GO 4 App. If you have forgotten your password since your initial login, you can reset it using a function within the DJI GO and DJI GO 4 apps.
You will need a data connection to the Internet for your smartphone or tablet when you log in, in order to verify the account information and activate the updated software or firmware. If this activation process is not performed, the aircraft will not have access to the correct geospatial information and flight functions for that region, and its operations will be restricted if you update the upcoming firmware: Live camera streaming will be disabled, and flight will be limited to a 50-meter (164-foot) radius up to 30 meters (98 feet) high.
You will be good to go after that
Rich |
