DJI Go App Editor and Photo Quality
1189 4 2017-7-2
Thumper
Flight distance : 453 ft
I am trying to work out the editor on the Go 4.0 app and how it works with the spark in terms of getting the content in full resolution onto my phone so it syncs with iCloud. Do I need to manually download the original content from my sd card on the spark or does it automatically sync up. I could not find any information on this and trying to work it out. Thanks
2017-7-2
fans47efb99f
Flight distance : 19902 ft
I can't download the full resolution images via the app either. Always fails and basically disconnects. I have also tested with my phone directly connect to the remote via usb and no luck.
2017-7-2
Ken-W
Flight distance : 394626 ft
Singapore
You need to go into Playback mode in the app (the Play button), and either download one or several using the Select button) onto your mobile device (I use an iPhone 6 Plus) and then edit from there. As for syncing with iCloud, as soon as I'm connected back to a network with internet connectivity, my iPhone's image library is synced to iCloud and I can access the images from any of my other iOS/Mac devices.
2017-7-2
Thumper
Ken-W Posted at 2017-7-2 04:40
Thanks for the advice, will give that a try.
I have since noticed that some pictures and videos are automatically in my photos on my iPhone without doing anything. I could not find a setting for this, do you know how to control this?
2017-7-3
Ken-W
United Arab Emirates
Thumper Posted at 2017-7-3 22:01
Nope. no idea. I usually just focus on flying and getting the shots I want, through several batteries, then on the last battery, I just download all the files from the aircraft to my iPhone before powering down.
The alternative is to not bother with transferring via WiFi. Just pull the microSD card and load it into your device using an external card reader. Much faster that way, especially when transferring videos.
2017-7-9
