RC after update
1245 6 2017-7-3
I 2 Fly
Flight distance : 8176 ft
South Africa
I did the latest updates on both the P4 P as well as the controller.  For the first time it took rather long but on the RC in particular!  After getting to 99% it did go no further - I left the RC connected for 20 min. at 99% and then had to switch off.
I must say the latest update was not such a good experience for me.  The P4 P now alerts me of obstacles in clear open sky - 30m up!  The camera is not centered either...
Is there a way to "refresh" the RC update like with the drone via Assistant 2??  (I already refreshed the drone and will test fly tomorrow)
2017-7-3
fansa7fc3a56
Mexico
that exactly happened to mine, now, there is no transmission signal... what should we do?
2017-7-3
mhoppes
Flight distance : 141302 ft
It's even easier than that, if you are asking about the R/C.  Go to the download page of DJI and download the Phantom 4 Pro controller software.  Unzip it and put the .bin file on an SD card.  Stick the SD card into the controller.  Then go to settings --> updates --> click the little lines in the upper right corner and do a local update.
2017-7-3
I'm sorry that only P4P+ with the screen can be updated the firmware via DJI Assistant 2, but yours is P4P, please downgrade the firmware by long pressing the icon on the right top corner of APP, then update to the latest version like you did before. Here are pictures for your reference.
2017-7-3
Nvar Kawan
Flight distance : 33 ft
Iraq
DJI Mindy Posted at 2017-7-3 21:32
there is no downgrade option after the last update.
2017-7-4
Nvar Kawan Posted at 2017-7-4 00:56
There is the option, the RC can be downgraded to V01.03.00.00, please check the screenshot below.
2017-7-4
I 2 Fly
South Africa
Thanks very much.  I'll try asap.
2017-7-4
